Vg Hangup Problem
Hello Support Team,
Been running my script for 2 days and working fine. Lats night it stopped working, ran the trace and it seems to error out and does not play the initial wave file any help would be appreciated ...
123528.44 5 linedevstate 2048 0 0
123528.44 5 callstate OFFERING 65978 0 4
123528.44 5 Answer the call at 3/14/2004 12:35:28 PM
123528.45 5 lineAnswer(65978) => 66296
123528.45 5 callinfo CALLEDID
123528.45 5 callinfo ORIGIN
123528.45 5 ring 0
123529.00 5 callstate CONNECTED 65978,1,0
123529.00 5 WorkingModeTAPI@Connected=
123529.00 5 WorkingModeScript@Connected=
123529.05 5 Inband detection not enabled
123529.05 5 StartLoadedVgs at 3/14/2004 12:35:29 PM
123529.05 5 tapi Reply (LineEvReply) ok 66296 0
123529.05 5 [WELCOME_MESSAGE] Number Input
123529.05 5 [WELCOME_MESSAGE] Playing (ttt-soundfiles\0MASTER\MESS-WELCOME.wav, ttt-soundfiles\0MASTER\MESS-PLEASE ENTER YOUR PIN.wav)
123529.05 5 PlaySoundStart err=[0 play PlaySoundStart ResetWavOutAndContinuePlay=>4] file[D:\TEETIMETAKER\ttt-soundfiles\0MASTER\MESS-WELCOME.wav,D:\TEETIMETAKER\ttt-soundfiles\0MASTER\MESS-PLEASE ENTER YOUR PIN.wav]
123529.05 5 PlaySoundStart line[5] err=[0 tr 5 waveOutOpen(id=0) MMSYSERR_ALLOCATED but hWaveOut = NULL] [C:\Program Files\VoiceGuide\system\voice\ErrorPlayingFile.wav]
123529.05 5 For Dialogic use: PCM 11Khz 8bit Mono
123529.05 5 Hanging up call... [srlib PlaySoundStart]
123529.05 5 RecSoundStop ok
123529.05 5 PlaySoundStop ok
123529.05 5 fnHangupCall end
123529.05 5 tapie PlayEnd old line=5 0 638765
123531.03 5 linedevstate 2048 0 0
123531.03 5 callstate IDLE 65978 0 0
123531.03 5 WorkingMode@Idle=
123531.05 5 tapi Reply (LineEvReply) ok 66279 0
123532.11 5 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
123532.11 5 ReinitTelephony due to IDLE start
123532.11 5 tapic lineDeallocateCall(MainCall:65978) 0
123532.25 5 lineOpen(5) => 0
123532.25 5 Waiting for a call...
123532.25 5 lineOpen(5)LineHandle=65610
123555.09 5 linedevstate 2048 0 0
123555.09 5 callstate OFFERING 66499 0 4
123555.09 5 Answer the call at 3/14/2004 12:35:55 PM
123555.11 5 lineAnswer(66499) => 65542
123555.11 5 callinfo CALLEDID
123555.11 5 callinfo ORIGIN
123555.11 5 ring 0
123555.66 5 callstate CONNECTED 66499,1,0
123555.66 5 WorkingModeTAPI@Connected=
123555.66 5 WorkingModeScript@Connected=
123555.69 5 Inband detection not enabled
123555.69 5 StartLoadedVgs at 3/14/2004 12:35:55 PM
123555.69 5 tapi Reply (LineEvReply) ok 65542 0
123555.70 5 [WELCOME_MESSAGE] Number Input
123555.70 5 [WELCOME_MESSAGE] Playing (ttt-soundfiles\0MASTER\MESS-WELCOME.wav, ttt-soundfiles\0MASTER\MESS-PLEASE ENTER YOUR PIN.wav)
123555.70 5 PlaySoundStart err=[0 play PlaySoundStart ResetWavOutAndContinuePlay=>4] file[D:\TEETIMETAKER\ttt-soundfiles\0MASTER\MESS-WELCOME.wav,D:\TEETIMETAKER\ttt-soundfiles\0MASTER\MESS-PLEASE ENTER YOUR PIN.wav]
123555.70 5 PlaySoundStart line[5] err=[0 tr 5 waveOutOpen(id=0) MMSYSERR_ALLOCATED but hWaveOut = NULL] [C:\Program Files\VoiceGuide\system\voice\ErrorPlayingFile.wav]
123555.70 5 For Dialogic use: PCM 11Khz 8bit Mono
123555.70 5 Hanging up call... [srlib PlaySoundStart]
123555.70 5 RecSoundStop ok
123555.70 5 PlaySoundStop ok
123555.70 5 fnHangupCall end
123555.70 5 tapie PlayEnd old line=5 0 665421
123555.72 5 tapie PlayEnd old line=5 0 665421
123557.69 5 linedevstate 2048 0 0
123557.69 5 callstate IDLE 66499 0 0
123557.69 5 WorkingMode@Idle=
123557.69 5 tapi Reply (LineEvReply) ok 65696 0
123558.75 5 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
123558.75 5 ReinitTelephony due to IDLE start
123558.75 5 tapic lineDeallocateCall(MainCall:66499) 0
123558.91 5 lineOpen(5) => 0
123558.91 5 Waiting for a call...
123558.91 5 lineOpen(5)LineHandle=66132
thanks -
Were any new sound card related software or drivers installed?
Looks like the wave drivers have stopped working.
Please re-install the wave drivers for your device (ie: uninstall and install again.)
If that does not work can you try removing all the wave drives on your system (including any sound card drivers) and then re-installing the wave drivers for your telephony device first.
