Tts Changes From 7.5.7 To 7.5.12
I have the Enterprise License and am using the Windows Server 2012 R2 SAPI TTS engine. in 5.7.5, I was using the Zira voice and had the SAPI section of the vg.ini set to this:
[sAPI]
;Which of the SAPI Engines VoiceGuide should use to do TTS. Set to DISABLE to stop loading TTS altogether. If left blank the default SAPI voice will be used.
TTSEngine=Microsoft Zira Desktop - English (United States)
SpStreamFormat=8khz8
;if the TTS engine does not support XML tags to regulate speed & volume of the generated Sound file.
;then use the entries below to control these settings. Other engines allow you to use XML tags to regulate speed/volume etc
;TTSspeed range is -10 to 10. 0 is default speed
TTSspeed=-1
;TTSvolume range is 0 to 100. 100 is max volume
TTSvolume=100
I have upgraded to v7.5.12 and the TTS voice has defaulted to MS David.
I get this info from the KTtts.txt file:
102502.194 1488 ktTtsSapi v7.5.12
102502.194 1488 log [C:\Program Files (x86)\VoiceGuide\log\] level=10 options []
102502.194 1488 ------------------------------------------------------------------------------
102502.194 1488 SpEnumTokens call
102502.197 1488 GetCount call
102502.197 1488 GetCount returned ulNumTokens=3
102502.197 1488 tts voice 0 : Microsoft David Desktop - English (United States)
102502.197 1488 HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Speech\Voices\Tokens\TTS_MS_EN-US_DAVID_11.0
102502.197 1488 tts voice 1 : Microsoft Hazel Desktop - English (Great Britain)
102502.197 1488 HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Speech\Voices\Tokens\TTS_MS_EN-GB_HAZEL_11.0
102502.197 1488 tts voice 2 : Microsoft Zira Desktop - English (United States)
102502.197 1488 HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Speech\Voices\Tokens\TTS_MS_EN-US_ZIRA_11.0
102502.197 1488 NOTE TTS engine used is set to first engine in list, as no TTS engine set in VG.INI [sAPI] TTSEngine entry. pToken=0C5023DC
102502.197 1488 Create tts thread. threadnumber= 1, handle= 2412 threadid= 5512
102502.197 1488 ThreadPriority -1
102502.198 5512 1 ProcessTTSJob thread created
102502.199 5512 1 cpSpStream=0C501618
The note says no TTSEngine entry was found. I have read the online help under configuration in the TTS section. It references a [TTS] section that is not in the ini file.
Here's the text I am referring to:
To use SAPI TTS engine the VG.INI [TTS] EngineType entry must be set to:
EngineType=SAPI
The SAPI_Engine entry then must be set to the SAPI TTS Engine to use. eg:
SAPI_Engine=Cepstral Allison-8kHz
The list of TTS engine names that are installed on the system can be obtained from the VoiceGuide ktTts trace log file. At the beginning of the trace file there will be a section that lists all SAPI engines installed on the system. That section looks something like this:
124244.953 2812 tts voice 0 : Microsoft Mary
124244.953 2812 tts voice 1 : Microsoft Mike
124244.953 2812 tts voice 2 : Microsoft Sam
124244.953 2812 tts voice 3 : Cepstral Allison-8kHz
124244.953 2812 tts voice 4 : Sample TTS Voice
The name of the engine is listed after the "tts voice X : " tag.
Read more at: http://www.voiceguide.com/vghelp/source/html/config_tts.htm
I tried adding a [TTS] section with these entries:
[TTS]
EngineType=SAPI
SAPI_Engine=Microsoft Zira Desktop - English (United States)
I am still getting the default David. I'm sure I have a syntax error or something else missing. Any help would be appreciated.
thanks!
Daryl
Please update this system to current latest version of VoiceGuide: v7.5.14
If you still encounter any issues please post vgEngine trace which captures system startup.
