Mixing A .wav With Text To Speech?
is it possible to, and if so, how do I, have a wave file say:
[.wav]: "Your number matches our customer"
[text to speech]: "Jones Corporation" (e.g. $RV[Get Customer Name])
[.wav]: "Press 1 if that's correct. If this is incorrect, enter 3 to go back and try again."
What module or mix of modules do I use, if this is possible?
Geoff
Just use 3 "Play" modules, linked by "Timeout 0" paths.
The replay count should be set to 0 in first two modules so that they immediately go to the next module after play finishes.
