Guest alexieno Report post Posted 03/16/2004 12:10 AM Dear Support! I am just about to purchase one of the following boards, could you please advise which board should I pick out of the following 2, and why: D4pcieuro or D4pciu I am located in Europe. Your help is much appreciated! Regards Alex Share this post Link to post
SupportTeam Report post Posted 03/16/2004 12:20 AM Either one is fine. The D/4PCIU is the newer card and will also work in the newer 3.3V PCI buses which are popular on high end servers. The D/4PCIEURO will not work on 3.3V PCI buses, but unless you are buying a top end server this should not be an issue. Share this post Link to post
Geoff R Report post Posted 04/13/2004 11:03 AM Which of these two cards would you recommend for use in Australia? Is there any other card you would recommend over these? Thanks Geoff Share this post Link to post
SupportTeam Report post Posted 04/13/2004 11:19 AM D/4PCI-EURO vs D/4PCIU does not matter - functionally it's the same card. The other current model 4 port analog card from Dialogic is the D/41JCT card. With D/41JCT you will be able to do "Dial and Conference" - whereas with D/4PCI "Dial and Conference" is not possible. For info on "Dial and Conference" see: http://www.voiceguide.com/vghelp/html/modXfer.htm Share this post Link to post
