Guest IVR_Newbie Report post Posted 03/16/2004 02:03 PM I used to be receiving Caller ID info, but then after I have successfully fixed the 'hangup' detection problems by changing the disconnect frequencies, somehow (co-incident or not) I find that I can no longer detect Caller ID, which always returned as blank. I have set the Line Config to pick up the call after even 4 rings (previously I only need to set it to 2 to detect Caller ID) Kind advise what could have happened. Thanks! (The event log is attached beneath.) 215807.31 6 linedevstate 2048 0 0 215807.31 6 callstate OFFERING 65605 0 4 215807.33 6 callinfo CALLEDID 215807.33 6 callinfo ORIGIN 215807.33 6 ring 0 215813.33 6 ring 2 215819.33 6 ring 3 215825.34 6 ring 4 215825.34 6 Start without answering the call 215825.34 6 StartLoadedVgs at 16/3/2004 21:58:25 215825.34 6 rv add [$RV_STARTTIME]{16/3/2004 21:58:25} 215825.34 6 rv add [$RV_DEVICEID]{6} 215825.34 6 rv add [$RV_CIDNAME]{} 215825.34 6 AddRVns [PathApp]{C:\Program Files\VoiceGuide\} 215825.34 6 rv add [$RV_CIDNUMBER]{} 215825.34 6 TimeoutClear 215825.34 6 [Call Alert] Running VB Script... 215825.34 6 RVreplace start: ['Script : Call Recorder.vgs 'Module : Call Alert set vg = CreateObject("VoiceGuide.CommandLink") if msgbox("Number : $RV_CIDNUMBER" & vbCrLf & "Name : $RV_CIDNAME", vbYesNo + vbQuestion , "Record Call ?") = vbYes then vg.Run_ResultReturn $RV_DEVICEID, "yes" else vg.Run_ResultReturn $RV_DEVICEID, "no" end if set vg = Nothing ] 215825.34 6 RVns [PathSysVoice]{}[PathApp]{C:\Program Files\VoiceGuide\}[PathDataVm]{C:\Program Files\VoiceGuide\data\}[PathVgSys]{C:\Program Files\VoiceGuide\system\}[$RV_STARTTIME]{16/3/2004 21:58:25}[$RV_DEVICEID]{6}[$RV_CIDNAME]{}[PathApp]{C:\Program Files\VoiceGuide\}[$RV_CIDNUMBER]{} 215825.38 6 Run Script waiting... (shellid=2776, process=1248) 215825.38 6 TimeoutSet 1 EV_TIMEOUT_CHECKONSTATE 215826.38 6 Timer fired EV_TIMEOUT_CHECKONSTATE 215826.38 6 ScriptEventCode 9007 iLineState=1501 215826.38 6 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE 215826.38 6 task still running (shellid=2776, process=1248) 215826.38 6 TimeoutSet 1 EV_TIMEOUT_CHECKONSTATE 215827.47 6 Timer fired EV_TIMEOUT_CHECKONSTATE 215827.47 6 ScriptEventCode 9007 iLineState=1501 215827.47 6 LsRunWaitTillFinished EV_TIMEOUT_CHECKONSTATE 215827.47 6 task still running (shellid=2776, process=1248) 215827.47 6 TimeoutSet 1 EV_TIMEOUT_CHECKONSTATE 215827.66 6 cl Run_ResultReturn >>no<< 215827.67 6 rv add [Call Alert_ResultReturn]{no} 215827.67 6 TimeoutClear 215827.67 6 rv add [Hangup Time]{16/3/2004 21:58:27} 215827.67 6 Hanging up call... [Hangup Module] 215827.67 6 HangupCall_Common Mode=BeforeAnswerRun 215831.34 6 ring 5 215837.34 6 ring 6 215838.75 6 linedevstate 2048 0 0 215838.75 6 callstate IDLE 65605 0 0 215838.75 6 WorkingMode@Idle= 215838.75 6 TimeoutClear 215838.77 6 TimeoutSet 1 EV_TIMEOUT_TIMETOREINITLINE 215839.83 6 Timer fired EV_TIMEOUT_TIMETOREINITLINE 215839.83 6 ScriptEventCode 9008 iLineState=900 215839.83 6 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE 215839.83 6 ReinitTelephony due to IDLE 215839.83 6 tapic lineDeallocateCall(MainCall:65605) 0 215839.88 6 lineOpen(6)=> 215839.88 6 Waiting for a call... 215839.88 6 LineHandle=66237 215839.88 6 TimeoutSet 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT 215843.16 6 Timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT 215843.16 6 ScriptEventCode 9013 iLineState=900 215851.83 0 sys cleanup Start 215851.83 0 sys cleanup End Share this post Link to post
SupportTeam Report post Posted 03/16/2004 09:01 PM Setting the disconnect tone frequencies/cadence does not affect the receiving of CallerID information. Have you tried attaching a CallerID monitoring device to this line to see if the phone company is sending CallerID on this line at all? Share this post Link to post
Guest IVR_Newbie Report post Posted 03/17/2004 02:38 PM Yes, I used a phone and the Caller ID did display correctly between the 1st and 2nd ring. Also, as I mentioned, it used to display correctly before my upgrade to 5.2.1 (don't know if the different version makes a difference). Please help. Thanks! Share this post Link to post
SupportTeam Report post Posted 03/17/2004 08:37 PM The trace shows that the telephony device is not reporting any Caller ID information to VoiceGuide. What telephony device are you using? (Dialogic?) Share this post Link to post
Guest IVR_Newbie Report post Posted 03/17/2004 09:51 PM Yes, it's Dialogic's D/4PCIU running on Windows 2000 Server. Share this post Link to post
SupportTeam Report post Posted 03/17/2004 10:00 PM Not too sure why a D/4PCI would stop reporting caller ID information. I'd probably try uninstalling all Dialogic drivers (entire 'System Release') and installing all again. Share this post Link to post
