Guest Geoff R Report post Posted 03/17/2004 05:09 AM Is there a way to ftp files to a server other than using VoiceMail boxes? I had hoped for a customer to simply record a message and then have it emailed, or ftp'd as required. If not, how do I integrate a VoiceMail system with a customer database so they can do these things? Many thanks Geoff Share this post Link to post
SupportTeam Report post Posted 03/17/2004 05:57 AM If you want to FTP yourself from within the VoiceGuide script you can just use a Run VB Script module to do the FTP. Take a look at the file vm_ftp.vbs in VoiceGuide's \system\vm\ subdirectory. That is the VB Script which is used by VG to FTP voicemail messages - you can use it almost 'as is' in a Run VB Script module within your script... Share this post Link to post
Guest Geoff R Report post Posted 03/18/2004 10:45 AM Thanks, very helpful. Share this post Link to post
