How to FTP files to a server from VG script
Is there a way to ftp files to a server other than using VoiceMail boxes? I had hoped for a customer to simply record a message and then have it emailed, or ftp'd as required.
If not, how do I integrate a VoiceMail system with a customer database so they can do these things?
Many thanks
Geoff
If you want to FTP yourself from within the VoiceGuide script you can just use a Run VB Script module to do the FTP.
Take a look at the file vm_ftp.vbs in VoiceGuide's \system\vm\ subdirectory.
That is the VB Script which is used by VG to FTP voicemail messages - you can use it almost 'as is' in a Run VB Script module within your script...
