Guest peggy Report post Posted 03/17/2004 10:18 AM hi, when the demo script, credit card payment, is run, a file in .csv format is created and all details are stored in it. may i know is it possible to change this file format to something else for eg, microsoft access or normal microsoft excel? thanks Share this post Link to post
SupportTeam Report post Posted 03/17/2004 11:43 AM Both MS Access and MS Excel can read the comma delimited (.csv) files... You can just open them directly in Access/Excel... If you wish to create your own log files please read the VG Help file's section on Run VB Script module - you can write out log entries of your own format using the Run VB Script modules and some examples are provided in the Help file. Share this post Link to post
Guest Guest Report post Posted 03/18/2004 06:45 AM But how do you input the entered data into the microsoft excel csv file? Can I have the algorithm (a general guideline)? Thanks Share this post Link to post
SupportTeam Report post Posted 03/18/2004 12:12 PM Just open the file in Excel... Go to "File" menu, then select "Open" then in the Open File window set the "Files Of Type" to be "Text Files"... Share this post Link to post
Guest Guest Report post Posted 03/19/2004 02:17 AM What I mean is can I set up my own database and then overide the csv file such that all details are saved automatically to my database instead of the csv file? If can, how do I go about doing that? Share this post Link to post
SupportTeam Report post Posted 03/19/2004 02:41 AM You can just write data to your database directly using a "DB Query" module... To create your own text files (comma delimited or XML etc.) then you can just use a "Run VB Script" to write information to file - see VG Help file's section on Run VB Script for more information - there are examples provided there on how to do this. Share this post Link to post
