Guest Frank Report post Posted 03/17/2004 09:22 PM I am looking at the help file "Send Phone Message" module. It says: VG Dialer option must be enabled to allow any outbounding dialing. How do you enable this option? Thank you Share this post Link to post
SupportTeam Report post Posted 03/17/2004 09:31 PM The Evaluation version has this enabled. See: http://www.voiceguide.com/vgFeatures.htm If you want to enable this when registering then you must buy the "Professional+Dialer" or "Enterprise+Dialer" license. See: https://bne052v.webcentral.com.au/vs7822_se...re/vg4order.htm If you have already purchased just a "Professional" or "Enterprise" license then you can purchase the Dialer add-on separately. Please see: https://bne052v.webcentral.com.au/vs7822_se...re/vg4order.htm Share this post Link to post
Guest Frank Report post Posted 03/17/2004 09:53 PM I bought "Enterprise+Dialer" license. Share this post Link to post
SupportTeam Report post Posted 03/17/2004 10:02 PM This means you have the "VG Dialer" option enabled and therefore can use the "Send Phone Message" modules in your script... Share this post Link to post
Guest Send Phone Message Report post Posted 03/18/2004 02:35 AM I don't understand how it works. After "Hangup Call" I would like "Send Phone Message" module to call my cell phone number(do I have to dial 1 at the beginning) and let me know that there was an incoming call. Thank you Share this post Link to post
SupportTeam Report post Posted 03/18/2004 04:15 AM You should use the "Send Phone Message" module before you use the "Hangup" module. Or, you can use the "On Hangup" script option and use the "Send Phone Message" module in that script... See: http://voiceguide.com/vghelp/html/Call%20Finish.htm Or, if the message is left in a voicemail box just configure that voicemail box to forward the message to your telephone number and all will be done automatically for you... Share this post Link to post
