DTMF Not Detecting...
i download today, install...and use with my usr robotic sportster v90
i script just one detect objet (for detect digit 5) and play sound if digit 5 is pressed...
but when detect dtmf is not available....
see the log :
172830,41 0 callstate OFFERING 65740 0 4
172830,41 0 ring 1
172835,36 0 ring 2
172835,36 0 Answer the call at 18/03/2004 17:28:35
172835,36 0 lineAnswer(65740) => 65723
172835,36 0 callstate ACCEPTED 65740 0 0
172835,80 0 tapi Reply (LineEvReply) ok 65723 0
172835,80 0 callstate CONNECTED 65740,0,0
172835,80 0 WorkingModeTAPI@Connected=
172835,80 0 WorkingModeScript@Connected=
172835,80 0 Inband detection not enabled
172835,80 0 StartLoadedVgs at 18/03/2004 17:28:35
172835,80 0 rv add [$RV_STARTTIME]{18/03/2004 17:28:35}
172835,81 0 rv add [$RV_DEVICEID]{0}
172835,81 0 rv add [$RV_CIDNAME]{}
172835,81 0 AddRVns [PathApp]{C:\Program Files\VoiceGuide\}
172835,81 0 rv add [$RV_CIDNUMBER]{}
172835,81 0 TimeoutClear
172835,81 0 [Get Numbers 11] Number Input
172835,81 0 [Get Numbers 11] Playing (C:\Program Files\NetMeeting\Blip.wav)
172836,55 0 PlaySoundStart ok [C:\Program Files\NetMeeting\Blip.wav]
172836,55 0 TimeoutClear
172836,56 0 wa(927,71268700)
172837,67 0 Play End line[0] (id=712687)
172837,67 0 ScriptEventCode 8001 iLineState=1300
172837,67 0 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED
172837,69 0 TimeoutSet 5 EV_TIMEOUT_REPLAYMSG
172843,05 0 Timer fired EV_TIMEOUT_REPLAYMSG
172843,05 0 ScriptEventCode 9005 iLineState=1301
172843,05 0 LsGetNbrsRxDigits EV_TIMEOUT_REPLAYMSG
172843,06 0 [Get Numbers 11] Playing (C:\Program Files\NetMeeting\Blip.wav)
172843,78 0 PlaySoundStart ok [C:\Program Files\NetMeeting\Blip.wav]
172843,78 0 TimeoutClear
172843,80 0 wa(927,71992100)
172844,91 0 Play End line[0] (id=719921)
172844,91 0 ScriptEventCode 8001 iLineState=1300
172844,91 0 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED
172844,92 0 TimeoutSet 5 EV_TIMEOUT_REPLAYMSG
172850,28 0 Timer fired EV_TIMEOUT_REPLAYMSG
172850,28 0 ScriptEventCode 9005 iLineState=1301
172850,28 0 LsGetNbrsRxDigits EV_TIMEOUT_REPLAYMSG
172850,30 0 [Get Numbers 11] Playing (C:\Program Files\NetMeeting\Blip.wav)
172851,02 0 PlaySoundStart ok [C:\Program Files\NetMeeting\Blip.wav]
172851,02 0 TimeoutClear
172851,03 0 wa(927,72715600)
172852,13 0 Play End line[0] (id=727156)
172852,14 0 ScriptEventCode 8001 iLineState=1300
172852,14 0 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED
172852,14 0 TimeoutSet 10 EV_TIMEOUT_HANGUP
172852,16 0 TimeoutSet 6 EV_TIMEOUT_ENTERDATA
172858,61 0 Timer fired EV_TIMEOUT_ENTERDATA
172858,61 0 ScriptEventCode 9006 iLineState=1301
172858,61 0 LsGetNbrsRxDigits EV_TIMEOUT_ENTERDATA
172858,63 0 rv add [Get Numbers 11]{}
172858,63 0 AddRVns [Get Numbers 11_PathTaken]{fail}
172858,63 0 rv add [Hangup Time]{18/03/2004 17:28:58}
172858,64 0 Hanging up call... [No data entered]
172858,64 0 RecSoundStop ok
172858,64 0 PlaySoundStop err=0
172858,66 0 TimeoutSet 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
172858,66 0 fnHangupCall end
172859,36 0 callstate DISCONNECTED 65740,1,0
172859,36 0 ScriptEventCode 9250 iLineState=900
172859,38 0 LsAwaitingCalls EV_REMOTEPARTY_DISCONNECT
172859,38 0 rv add [Hangup Time]{18/03/2004 17:28:59}
172859,39 0 Hanging up call...
172859,39 0 RecSoundStop ok
172859,39 0 PlaySoundStop err=0
172859,41 0 TimeoutSet 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
172859,41 0 fnHangupCall end
172859,41 0 callstate IDLE 65740 0 0
172859,42 0 WorkingMode@Idle=
172859,42 0 TimeoutClear
172859,42 0 TimeoutSet 1 EV_TIMEOUT_TIMETOREINITLINE
172859,44 0 tapi Reply (LineEvReply) ok 65706 0
172859,44 0 tapi Reply (LineEvReply) ok 65689 0
172900,42 0 Timer fired EV_TIMEOUT_TIMETOREINITLINE
172900,42 0 ScriptEventCode 9008 iLineState=900
172900,42 0 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
172900,44 0 ReinitTelephony due to IDLE
172900,44 0 tapic lineDeallocateCall(MainCall:65740) 0
172900,45 0 lineOpen(0)=>
172900,45 0 Waiting for a call...
172900,45 0 LineHandle=65672
172900,47 0 TimeoutSet 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
172902,53 0 callstate OFFERING 65621 0 4
172902,55 0 ring 1
172903,75 0 Timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
172903,75 0 ScriptEventCode 9013 iLineState=900
172907,48 0 ring 2
172907,50 0 Answer the call at 18/03/2004 17:29:07
172907,50 0 lineAnswer(65621) => 65604
172907,52 0 callstate ACCEPTED 65621 0 0
172907,94 0 tapi Reply (LineEvReply) ok 65604 0
172907,94 0 callstate CONNECTED 65621,0,0
172907,95 0 WorkingModeTAPI@Connected=
172907,95 0 WorkingModeScript@Connected=
172907,95 0 Inband detection not enabled
172907,97 0 StartLoadedVgs at 18/03/2004 17:29:07
172907,97 0 rv add [$RV_STARTTIME]{18/03/2004 17:29:07}
172907,97 0 rv add [$RV_DEVICEID]{0}
172907,98 0 rv add [$RV_CIDNAME]{}
172907,98 0 AddRVns [PathApp]{C:\Program Files\VoiceGuide\}
172907,98 0 rv add [$RV_CIDNUMBER]{}
172908,00 0 TimeoutClear
172908,00 0 [Get Numbers 11] Number Input
172908,00 0 [Get Numbers 11] Playing (C:\Program Files\NetMeeting\Blip.wav)
172908,73 0 PlaySoundStart ok [C:\Program Files\NetMeeting\Blip.wav]
172908,73 0 TimeoutClear
172908,75 0 wa(927,74487500)
172909,86 0 Play End line[0] (id=744875)
172909,86 0 ScriptEventCode 8001 iLineState=1300
172909,86 0 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED
172909,88 0 TimeoutSet 5 EV_TIMEOUT_REPLAYMSG
172915,23 0 Timer fired EV_TIMEOUT_REPLAYMSG
172915,23 0 ScriptEventCode 9005 iLineState=1301
172915,23 0 LsGetNbrsRxDigits EV_TIMEOUT_REPLAYMSG
172915,25 0 [Get Numbers 11] Playing (C:\Program Files\NetMeeting\Blip.wav)
172915,97 0 PlaySoundStart ok [C:\Program Files\NetMeeting\Blip.wav]
172915,97 0 TimeoutClear
172915,98 0 wa(927,75210900)
172917,09 0 Play End line[0] (id=752109)
172917,09 0 ScriptEventCode 8001 iLineState=1300
172917,11 0 LsGetNbrsPlayWelcMsg EV_PLAY_FINISHED
172917,11 0 TimeoutSet 5 EV_TIMEOUT_REPLAYMSG
172921,00 0 callstate DISCONNECTED 65621,32,0
172921,02 0 ScriptEventCode 9250 iLineState=1301
172921,02 0 LsGetNbrsRxDigits EV_REMOTEPARTY_DISCONNECT
172921,02 0 rv add [Get Numbers 11]{}
172921,03 0 rv add [Hangup Time]{18/03/2004 17:29:21}
172921,03 0 Hanging up call...
172921,03 0 RecSoundStop ok
172921,05 0 PlaySoundStop err=0
172921,05 0 TimeoutSet 2 EV_TIMEOUT_WAITFORIDLEAFTERLINEDROP
172921,05 0 fnHangupCall end
172921,75 0 callstate IDLE 65621 0 0
172921,77 0 WorkingMode@Idle=
172921,77 0 TimeoutClear
172921,78 0 TimeoutSet 1 EV_TIMEOUT_TIMETOREINITLINE
172921,78 0 tapi Reply (LineEvReply) ok 65587 0
172922,81 0 Timer fired EV_TIMEOUT_TIMETOREINITLINE
172922,81 0 ScriptEventCode 9008 iLineState=900
172922,81 0 LsAwaitingCalls EV_TIMEOUT_TIMETOREINITLINE
172922,83 0 ReinitTelephony due to IDLE
172922,83 0 tapic lineDeallocateCall(MainCall:65621) 0
172922,84 0 lineOpen(0)=>
172922,84 0 Waiting for a call...
172922,84 0 LineHandle=65570
172922,86 0 TimeoutSet 3 EV_TIMEOUT_ATERIDLE_ALLOWOUT
172926,14 0 Timer fired EV_TIMEOUT_ATERIDLE_ALLOWOUT
172926,14 0 ScriptEventCode 9013 iLineState=900
