Guest ThaoHuynh Report post Posted 01/18/2018 04:08 AM Hi VG Team, I would like to set timeout of moduleGetNbrs is 10. So i have modified the setting using vg.ini: Section:[moduleGetNbrs]entries:Timeout_1stDigit=10Timeout_Interdigit=10Timeout_Confirm=10 But when i run vg script to test, and check log file it's still not set, although i have restarted voiceguide system. [moduleGetNbrs]:Timeout_1stDigit not set. default is 6 [moduleGetNbrs]:Timeout_Interdigit not set. default is 6 [moduleGetNbrs]:Timeout_Confirm not set. default is 6 Thank you for your support Share this post Link to post
SupportTeam Report post Posted 01/18/2018 07:18 AM Could you please post the VG.INI file and the vgEngine trace that captures the latest VoiceGuide service restart. Share this post Link to post
