My Ms Access Database Won't Connect
I am running the trial version of VoiceGuide but I am having problems with the Database Module. I try to connect to the database using MS Access but it never responds. I have tried the request line in the help but it never works. I need someone that has used the Database Module with MS Access to please give me some tips and send me his request line. I also tried using the ODBC to access the same MS Access database and it wasn't successful.
Operating system: Windows 2000 Professional.
Voice Guide Version: Version 4.8.45
Any help along this line will be appreciated. Thanks.
Femi.
Could you please post the script that you are using, and also could you please post a copy of VoiceGuide's Debug Printout which captures the database query attempt, this will allow us to see what is going wrong.
Thanks for the lead you gave me. I checked the trace logs and found that I was specifying the wrong variable type in my query. I corrected the error and the MS Access database query works well, also when using ODBC, it works very well.
Thanks, and how do I become a registered member of the forum. Is it when I have registered the product that I can become a registered member of the support forum.
Bye.
You can register yourself as a member of the forum anytime - see the 'Register' option at top left of page...
The main advantage of registration is that you can have posts to threads you select emailed you immediately...
