Guest Ercan Report post Posted 04/05/2018 08:13 PM Hi , I have result from RESTApi GET call like {{"today":{"times":{"id":"Persembe_0","checked":true,"time":"09:00"}}}} I am trying to pass "time":"09:00" to next RESTApi POST as JSON. But if I try to send POST data like {"rzv":{ "username":$RV[TC_NO_SES], "time" :$RV[CheckTC_today_times_time], "type" : "today" } } it replace "time" :$RV[CheckTC_today_times_time] to => "time" :09:00 and it give JSON parse error. Because 09:00 not a string. How can I convert it to String? I tried adding "time" :$RV[CheckTC_today_times_time_string] but it gave me not found error like below 225249.359 8 2 2 3 rv replace start ------------------------------ {"rzv":{ "username":$RV[TC_NO_SES], "time" :$RV[CheckTC_today_times_time_string], "type" : "today" } } ------------------------------ 225249.359 8 2 2 3 rv dbg rv_retrieve did not find [CheckTC_today_times_time_string] 225249.359 8 2 2 3 rv replace end ------------------------------ {"rzv":{ "username":11111111111, "time" :, "type" : "today" } } ------------------------------ Share this post Link to post
SupportTeam Report post Posted 04/05/2018 08:21 PM Please try using: {"rzv":{ "username":"$RV[TC_NO_SES]", "time" : "$RV[CheckTC_today_times_time]", "type" : "today" } } Note the double quotes added around the $RV placeholders. The $RVs are replaced with the text the contain only. If you would like to have quotes etc. around the replaced value then those need to be included by you in the template. Also, if a $RV is not defined then it is replaced with an empty string. The $RV[CheckTC_today_times_time_string] was most likely not defined. The Web Service module does not create "_string" etc. subtyped versions of $RVs. The vgEngine trace shows all the $RVs created during the call by each of the modules in the script. The vgEngine trace is in VoiceGuide's \log\ subdirectory. Please let us know if you have any questions, Share this post Link to post
