Guest Thanh Nguuyen Report post Posted 04/12/2018 05:13 AM Hi Support Team Thanks for your support. I was upgrade from V6.0. to V7.5.19 , i have problem at module VBScript, it error occurred and voiceguide hanged. VBScript module [ set fso = CreateObject("Scripting.FileSystemObject") set fileLocalData = fso.OpenTextFile("$RV_PathScript\" + "localinfo.txt") sEntireFile = fileLocalData.ReadAll set fileLocalData = Nothing set fso = Nothing set vg = CreateObject("vgServices.CommandLink") vg.Run_ResultReturn $RV_LINEID, sEntireFile set vg = Nothing ] ------------------------------ 120200.855 7 3 1 1 vbs saving script - yes (UsingClearScript=True, strIni_moduleRunScript_SaveToFile=1) 120200.855 7 3 1 1 vbs delete existing: C:\Program Files (x86)\VoiceGuide\temp\vbs_3_1.vbs 120200.865 7 3 1 1 vbs script written to (overwriting previous): C:\Program Files (x86)\VoiceGuide\temp\vbs_3_1.vbs 120200.865 7 3 1 1 runscr will be waiting. wait=1, calling iModuleIdx=30 (setting iRunWait_VgmIdx to 30) 120200.867 7 3 1 1 moh not set 120200.867 7 AvailablePhysicalMemory=2585 MB 120200.867 7 3 1 1 runscr ClearScript VBScriptEngine used 120200.893 7 3 1 1 runscr .Execute call 120200.900 7 3 1 1 ERROR RunScript_ClearScript_ScriptEngineException ERROR ErrorDetails: File not found ERROR Message: File not found ERROR Source: ClearScript ERROR StackTrace: at Microsoft.ClearScript.ScriptEngine.ThrowScriptError(IScriptEngineException scriptError) at Microsoft.ClearScript.Windows.WindowsScriptEngine.ThrowScriptError(Exception exception) at Microsoft.ClearScript.Windows.WindowsScriptEngine.<>c__DisplayClass1e`1.<ScriptInvoke>b__1d() at Microsoft.ClearScript.ScriptEngine.ScriptInvoke[T](Func`1 func) at Microsoft.ClearScript.Windows.WindowsScriptEngine.ScriptInvoke[T](Func`1 func) at Microsoft.ClearScript.Windows.WindowsScriptEngine.Execute(String documentName, String code, Boolean evaluate, Boolean discard) at (Object , String ) at ..(Object oParam) 120200.900 7 3 1 1 note If this error persists try using Windows Scripting Host engine, by adding this entry to [moduleRunScript] section of VG.INI : Engine=WSH 120200.900 7 3 1 1 runscr dispose call 120200.901 7 3 1 1 runscr using WSH instead (as ClearScript error). save vbs to to file 120200.901 7 3 1 1 vbs delete existing: C:\Program Files (x86)\VoiceGuide\temp\vbs_3_1.vbs 120200.903 7 3 1 1 vbs script written to (overwriting previous): C:\Program Files (x86)\VoiceGuide\temp\vbs_3_1.vbs 120200.904 7 3 1 1 runscr start - Run_VBS_UsingExternalInterpreter [C:\Program Files (x86)\VoiceGuide\temp\vbs_3_1.vbs] Share this post Link to post
SupportTeam Report post Posted 04/12/2018 06:00 AM Could ypu please .ZIP up and post the C:\Program Files (x86)\VoiceGuide\temp\vbs_3_1.vbs file ? The error message is: "File not found", so is it possible that this expression: "$RV_PathScript\" + "localinfo.txt" does not point to an existing file? Viewing vbs_3_1.vbs will let you see the full path of the file passed to the fso.OpenTextFile function. Share this post Link to post
Guest Thanh Nguuyen Report post Posted 04/12/2018 07:58 AM Great! thanks for your support Share this post Link to post
