Guest Ercan Report post Posted 04/18/2018 09:59 AM Hi, Suddenly my web service calls started to throw 407 error. I did not changed any configuration. What should be the problem ? I can't figure it. thanks. rv replace start ------------------------------ https://er-z.herokuapp.com/telRandevu/available/$RV[TC_NO_SES] ------------------------------ 125633.671 8 2 2 7 rv replace end ------------------------------ https://er-z.herokuapp.com/telRandevu/available/11111111111 ------------------------------ 125633.671 8 2 2 7 que modWs.RunModule_WebService, modCurrentModuleWs.hash=27356029, zModTaskParams.hash=-1182080340 125633.671 21 2 2 7 ws RunModule_WebService start iModuleIdx=27, iRunWait=1 125633.671 21 2 2 7 ws sLogFromConstructor: taskParams_in.hash=-1182080340, taskParams.hash=-1182080340 125633.671 21 2 2 7 ws RunModule_WebService start taskParams.hash=-1182080340 125633.671 21 2 2 7 ws PlayOnHoldFile 125633.671 21 2 2 7 moh not set 125633.671 21 2 2 7 ws WebRequest.Create [https://er-z.herokuapp.com/telRandevu/available/11111111111 ] call 125633.671 21 2 2 7 ws request.Method=[GET] 125633.671 21 2 2 7 ws request.ServicePoint.CurrentConnections call. 125633.671 21 2 2 7 ws CurrentConnections=0/2, ReceiveBufferSize=-1, Expect100Continue=False 125633.671 21 2 2 7 ws sp.ConnectionLeaseTimeout=0, spm.DefaultConnectionLimit=2, spm.DefaultPersistentConnectionLimit=2 125633.671 21 2 2 7 ws new RequestState call 125633.671 21 2 2 7 ws request.ReadWriteTimeout=30000, taskParams.iWsTimeoutMs_GoToAnotherModule=-1 125633.671 21 2 2 7 ws taskParams.clsRequestState.hash=35619699 125633.671 21 2 2 7 ws BeginGetResponse (GetWsResponse_Callback) call. ReadWriteTimeout=30000 125633.750 21 2 2 7 ws BeginGetResponse returned 125643.078 13 2 2 7 ws GetWsResponse_Callback start. class' taskParams.hash=-1182080340 clsRequestStateData.taskParams.hash=-1182080340 125643.078 13 2 2 7 ws GetWsResponse_Callback request.hash=29742526 125643.078 13 2 2 7 ws GetWsResponse_Callback start [CheckTC], time since WsUserWorkItemCreated=00:00:09.4062500 125643.078 13 2 2 7 ws GetWsResponse_Callback WebException wex.Message=Temel al?nan ba?lant? kapat?ld?: G?nderme i?leminde beklenmeyen hata olu?tu. 125643.078 13 2 2 7 ModuleCompleted_WebServiceCall [470] : [WebException] 125643.078 13 2 2 7 path {470} not found 125643.078 13 2 2 7 path {WebException} not found 125643.078 13 2 2 7 path {Temel al?nan ba?lant? kapat?ld?: G?nderme i?leminde beklenmeyen hata olu?tu.} not found 125643.078 13 2 2 7 path {CLIENT_ERROR} not found 125643.078 13 2 2 7 path {ERROR} not found 125643.078 13 2 2 7 FindNextVgmTitleInPathList: next module title is=[NO_USER] 125643.078 13 2 2 7 RunModule_AddToTaskQueue [Play,[NO_USER],28] 125643.078 13 2 2 7 q_scr + evScriptEvent 9800 CMD_RUN_SAME_MODULE_AGAIN 125643.078 8 2 2 7 q_scr run evScriptEvent sCode=[CMD_RUN_SAME_MODULE_AGAIN] iActionID=0, crn=0 [0|0|0|0|0][|||||] 00:00:00 max:2|00:00:00.1875000 125643.078 8 2 2 7 se CMD_RUN_SAME_MODULE_AGAIN 9800 0|0|0 || LineState=LS_WS_CALL 125643.078 8 2 2 7 t timer clear (force=False) 125643.078 8 2 2 7 RunModule start Play, [NO_USER], iModuleIdx=28, previous: vgm=28, vgs=3:3 Share this post Link to post
SupportTeam Report post Posted 04/18/2018 10:48 AM Next step would be to trace the messages between VoiceGuide and your web service. You can use WireShark to capture the trace. It would be easier to view the messages if you could switch to http instead of https. Is there any tracing on the web service side that wold show you the incoming requests from VoiceGuide and whether they were processed. Translation of the error message: "Temel al?nan ba?lant? kapat?ld?: G?nderme i?leminde beklenmeyen hata olu?tu." suggests that perhaps the web service did not respond to the GET request (?) Share this post Link to post
Guest Ercan Report post Posted 04/18/2018 06:39 PM Hi, web service does not get any incoming request from Voice Guide. But if i try via browser it works. It was working smoothly, suddenly stopped sending request from VoiceGuide Web service module. Is there any timeout configuration for Web service call? Share this post Link to post
SupportTeam Report post Posted 04/18/2018 10:57 PM Looks like some sort of a connectivity issue that triggers a timeout at around 10 seconds. Was there any anti-virus etc type software installed recently on this system or were the firewall settings changed? Are you running the latest version of VoiceGuide? Is it registered or is it running in evaluation mode? Does the issue remain present after restarting the VoiceGuide service? Share this post Link to post
SupportTeam Report post Posted 04/22/2018 06:35 AM Also, it looks like the first call to the https api which you are using takes a long time to respond, but subsequent calls return quickly. So perhaps there is something in the process handling that GET request that results in it taking a long time the first time it is called after a longer time of not being used ? The response time for first call is of the order of 10 seconds, which is about the time at which the " "Temel al?nan ba?lant? ... " error was returned. Share this post Link to post
