Forget how to select load script on version 7
Dear sir
Forget how to select load script on version 7 on telephone line 3
Script to be used at call answer time is set in VoiceGuide's Config.xml file. (in the \conf\ subdirectory)
Each channel can have its own individual starting script set. (it can be the same script for all channels, and usually is)
Often the initial script acts a 'routing' script that jumps to a different script depending on the indial number (DNIS) etc.
