invoso.com Report post Posted 05/18/2018 12:17 PM how to add $RV[Hangup Source] to cdr tables? Share this post Link to post
SupportTeam Report post Posted 05/18/2018 01:00 PM The following $RVs are saved in the CDR: Contents of $RV[CDR_amaflags] will be placed in the 16th CDR field. Contents of $RV[CDR_user] will be placed in the 17th CDR field. In the 'After Hangup' script assign the value of $RV[Hangup Source] to $RV[CDR_user], and then the value of $RV[Hangup Source] will be saved in the CDR's 17th field. Easiest way to do the assignment would be to use the Evaluate Expression module. See: https://www.voiceguide.com/vghelp/source/html/log_cdrs.htm https://www.voiceguide.com/vghelp/source/html/modevalexpr.htm Share this post Link to post
