variable in paths?
Can we use variable as paths option?
in case
on {0} goto [first]
on {1} goto [second]
on {timeout 5} goto [Hangup the Call]
declare:
$RV[option1] = 'on {0} goto [first]'
$RV[option2] = 'on {1} goto [second]'
$RV[option3] = 'on {1} goto [second]'
use in paths:
$RV[option1]
$RV[option2]
$RV[option3]
$RVs can be used in Paths expressions.
Any $RVs in paths are evaluated before the Paths expression used to determine what action is taken after an event arrives.
The Paths definitions after $RV replacement must be valid, with all paths in this format:
On {Trigger} Goto [Module Title]
Your example above should work.
assigning all three lines to one $RV and specifying just that one $RV should also work.
This approach would also work:
on {$RV[option1]} goto [first]
on {$RV[option2]} goto [second]
on {$RV[option3]} goto [Hangup the Call]
where $RV[option1] - $RV[option3] are assigned keypad digits or other events triggers.
And this approach would also work:
on {1} goto [$RV[option1]]
on {2} goto [$RV[option2]]
on {3} goto [$RV[option3]]
where $RV[option1] - $RV[option3] are assigned module titles.
etc.
