Guest Panos Report post Posted 08/16/2018 09:57 AM Hello We want to find if a phone is our database and have some criteria like the expiredate between 2 dates The query is the SELECT Tel,DateExpire,AREA,CODE,CARD,phone,Price,paratirisi,DatelastRenewal FROM Customers WHERE DateExpire between #1/1/2017# And #12/30/2017# and (tel=right('$RV_CIDNUMBER',10) or area =right('$RV_CIDNUMBER',10) or phone= right('$RV_CIDNUMBER',10)) If the query returns a row we want to go to a specific module and if not to go to other module. The problem is that its always goes to the same module like it never find the row. I am sending you the logs and the script. What we have wrong? Thank you logs.zip Share this post Link to post
SupportTeam Report post Posted 08/16/2018 10:32 AM Suggest you take a look Suggest taking a look at the [ExpireDat] module's configuration. Looks like [ExpireDat] module is set to use a (non-existing) ODBC connection. Other database query modules in the script just specify to use C:\Expires\Syndromes.mdb database directly, without ODBC. And traces show that other modules can read that database with no problems. But [ExpireDat] module throws an error as the ODBC connector does not exist. If you can post the "Expires 2016 2017.vgs" script file we can open in the Script Designer and point out the configuration error. NB. Trace shows: 115134.843 6 3 2 state [ExpireDat] DB Query 115134.844 6 3 2 db strDatabaseName=[C:\Expires\Syndromes.mdb] strDbConnectString=[ODBC;DRIVER={Microsoft Access Driver (*.mdb)}] sAdoNetFactoriesAvailable=[|System.Data.Odbc|System.Data.OleDb|System.Data.OracleClient|System.Data.SqlClient|System.Data.SQLite|Npgsql|] 115134.844 6 3 2 db did not find ado.net data provider : C:\Expires\Syndromes.mdb 115134.844 6 3 2 db PlayOnHoldFile 115134.844 6 3 2 moh file not specified 115134.844 6 3 2 db using ado.net ODBC data provider : OdbcConnection/OdbcCommand/etc 115134.849 6 3 2 db odbc RunQuery_Odbc [ExpireDat], db=[], connect=[DRIVER={Microsoft Access Driver (*.mdb)}], sql=[SELECT Tel,DateExpire,AREA,CODE,CARD,phone,Price,paratirisi,DatelastRenewal FROM Customers WHERE DateExpire between #1/1/2017# And #12/30/2017#] 115134.849 6 3 2 odbc DSN not specified, using a DSN-less ODBC connection. 115134.849 6 3 2 db odbc thread init (threadpool) 115134.849 6 3 2 db odbc thread started (threadpool) 115134.849 6 3 2 t timer set 30 sec : EV_TIMEOUT_HANGUP 115134.867 15 3 2 db odbc connection create call. 115134.868 15 3 2 db odbc connection open call. 115134.875 4 3 2 db oledb ConnectAndRun_OleDb thread completed. 115135.149 15 3 2 ERROR v0.0.0.0 (2013-05-02 23:45:07.90) ConnectAndRun_Odbc init : ERROR [IM006] [Microsoft][?????????? ???????????? ???????? ODBC] ? SQLSetConnectAttr ??? ???????????? ???????? ??????? ?? System.Data.Odbc.OdbcConnection.HandleError(OdbcHandle hrHandle, RetCode retcode) ?? System.Data.Odbc.OdbcConnectionHandle..ctor(OdbcConnection connection, OdbcConnectionString constr, OdbcEnvironmentHandle environmentHandle) ?? System.Data.Odbc.OdbcConnectionOpen..ctor(OdbcConnection outerConnection, OdbcConnectionString connectionOptions) ?? System.Data.Odbc.OdbcConnectionFactory.CreateConnection(DbConnectionOptions options, Object poolGroupProviderInfo, DbConnectionPool pool, DbConnection owningObject) ?? System.Data.ProviderBase.DbConnectionFactory.CreateNonPooledConnection(DbConnection owningConnection, DbConnectionPoolGroup poolGroup) ?? System.Data.ProviderBase.DbConnectionFactory.GetConnection(DbConnection owningConnection) ?? System.Data.ProviderBase.DbConnectionClosed.OpenConnection(DbConnection outerConnection, DbConnectionFactory connectionFactory) ?? System.Data.Odbc.OdbcConnection.Open() ?? �.�.�() 115135.149 15 3 2 db completed. SqlQueryType=ERROR, RowsCount=0, sRv= 115135.149 15 3 2 db completed. iRunWait=1, WavPlayWasStarted=0, WavPlayHasNowFinished=0 115135.149 15 3 2 db completed. strError=ERROR [IM006] [Microsoft][?????????? ???????????? ???????? ODBC] ? SQLSetConnectAttr ??? ???????????? ???????? ??????? 115135.149 15 3 2 path {ERROR [IM006] [Microsoft][?????????? ???????????? ???????? ODBC] ? SQLSetConnectAttr ??? ???????????? ???????? ???????} not found 115135.149 15 3 2 path {ERROR} not found 115135.149 15 3 2 path {error} not found 115135.149 15 3 2 FindNextVgmTitleInPathList: next module title is=[Database] 115135.150 15 3 2 RunModule_AddToTaskQueue [Database Query,[Database],11] Share this post Link to post
Guest Panos Report post Posted 08/18/2018 09:01 AM Its the same like the other modules You can see it in the photo Share this post Link to post
Guest Panos Report post Posted 08/18/2018 09:41 AM OK ist working now. Thans a lot Share this post Link to post
