jiaseby Report post Posted 10/18/2018 07:30 PM I'm looking to use a Text to Speech program to create my .wav files. The one I'm using is Natrual Reader. When I put the file in and test it, it sounds like a lion roaring. Am I doing something that isn't allowed? When I click on the file it plays the correct content. When I dial in it just roars. Share this post Link to post
SupportTeam Report post Posted 10/18/2018 07:36 PM Can you please .ZIP up the sound file and post the .ZIP here. We can then see what format the sound file is in. Also, which version of VoiceGuide are you using? If you can post latest ktTel trace from VoiceGuide's \log\ subdirectory which captures the playing of the sound file then that would let us see how the file was interpreted. (please .ZIP up the ktTel log before posting it). Share this post Link to post
jiaseby Report post Posted 10/18/2018 10:59 PM Here is the .wav file. MainMessage.wav Share this post Link to post
SupportTeam Report post Posted 10/19/2018 01:19 AM The sound file attached in previous post above is in format: "PCM 48kHz 8 bit Mono" That format is not supported. Please see here for sound file formats supported: https://www.voiceguide.com/vghelp/source/html/soundfiles.htm For VoiceGuide v7 the supported .WAV formats are: "PCM: 8kHz or 11kHz, 8-bit or 16-bit, Mono" We converted the supplied file to an 8kHz version (see attached at bottom of this post), but best results would be obtained if you can get the TTS engine to directly create the .WAV file in correct format, as any conversion of format afterwards adds noise/hiss to the output sound file. If the TTS engine is SAPI and it is installed on the VoiceGuide system then VoiceGuide would be able to use this TTS engine directly during the call. Please see here for information on how to configure: https://www.voiceguide.com/vghelp/source/html/config_tts.htm The generated TTS sound files are saved in VoiceGuide's \temp\ subdirectory. Those generated .WAV sound files can then be copied to another location and used in subsequent calls directly, without the need to invoke TTS engine again. (ie. just play it as any other .WAV file) MainMessage_pcm8kHz.wav Share this post Link to post
George G Report post Posted 10/23/2018 12:13 AM I have same issue. Can you recommend speech Syntesizer program? I tried textsound but client is not happy they say the voice is bad. Any idea why? We talk about wav files. I need command line interface syntesizer Share this post Link to post
SupportTeam Report post Posted 10/25/2018 05:43 AM Many 3rd party programs will just use whatever TTS engines are installed on your computer to generate the sound files. Suggest you take a look at and demo this one: https://www.cepstral.com/en/telephony/windows There are a number of other providers of TTS engines as well. If you install the TTS engine on VoiceGuide server then instruction on configuring VoiceGuide to use that TTS engine are here: https://www.voiceguide.com/vghelp/source/html/config_tts.htm Soon VoiceGuide will also support playing of Google Cloud TTS. You can demo it here: https://cloud.google.com/text-to-speech/ Share this post Link to post
