Guest mohammedzoheb Report post Posted 01/21/2019 12:49 PM On 21/06/2013 at 10:03 AM, SupportTeam said: strRet = vg.Record_2Lines_Start($RV[Conf_LineId_1], $RV[Conf_LineId_1], $RV[Conf_LineId_2], "c:\MyRecFile.wav", "") i used this for 2line recording but file is creating with no soung please check the attach log. 0121_ktTel.txt rec_1541_55_4.wav Config.xml Share this post Link to post
SupportTeam Report post Posted 01/21/2019 12:59 PM Please post VoiceGuide's vgEngine trace file that captures the 2-line recording attempts (the ones at 15:25 an 15:41). Please .ZIP up all the trace files before posting them and just post the .ZIP file. Share this post Link to post
Guest mohammedzoheb Report post Posted 01/21/2019 01:03 PM ok Please check the zip file . Share this post Link to post
SupportTeam Report post Posted 01/22/2019 01:48 AM Your Config.xml has a list of "Pool_Voice" devices specified as devices to be loaded. That Pool_Voice list should not be there. Please remove this entire <Pools><Pool_Voice> section and then restart the VoiceGuide service (to load the new Config.xml). Specifying non-existing devices in that pool is what is causing errors when those devices are attempted to be used. Can you please advise from where did you get this Pool_Voice information. We will need to modify that source to ensure that it is made more clear under what configurations the Pool_Voice can be used. Your current HMP license only has 4 voice resources, one of each call handling port. To use the additional Pool_Voice devices you will need to purchase additional voice resources. But you do not need to create pools of devices to perform 2-line recording, unless you have special requirements like being able to play whispers to each side of conversation while recording etc. Here is the section that needs to be removed: <Pools> <Pool_Voice> <Device_Voice>dxxxB17C1</Device_Voice> <Device_Voice>dxxxB17C2</Device_Voice> <Device_Voice>dxxxB17C3</Device_Voice> <Device_Voice>dxxxB17C4</Device_Voice> <Device_Voice>dxxxB18C1</Device_Voice> <Device_Voice>dxxxB18C2</Device_Voice> ... <Device_Voice>dxxxB30C3</Device_Voice> <Device_Voice>dxxxB30C4</Device_Voice> <Device_Voice>dxxxB31C1</Device_Voice> <Device_Voice>dxxxB31C2</Device_Voice> <Device_Voice>dxxxB31C3</Device_Voice> <Device_Voice>dxxxB31C4</Device_Voice> <Device_Voice>dxxxB32C1</Device_Voice> <Device_Voice>dxxxB32C2</Device_Voice> </Pool_Voice> </Pools> Share this post Link to post
Guest mohammedzoheb Report post Posted 01/22/2019 11:43 AM I was searching for 2line recording in one of the Forum i saw this and applied any how i removed now its working fine.Thanks Share this post Link to post
