tabla cdr
Buenas noches,
Por favor me pueden ayudar indicando que proceso debo realizar para poder llenar la tabla cdr pues cuando trabajo con la base sqlite del programa si graba pero cuando hago una conexion con mi base sql no graba.
mil gracias
Google Translate:
Goodnight,
Please can you help me by indicating what process I should perform in order to fill the cdr table because when I work with the sqlite base of the program if I record but when I make a connection with my sql database it does not record.
thank you
This looks like list of CDR entries for outgoing calls that were never connected.
If you can you post the vgEngine and ktTel traces for the day those calls were made we can then better advise what happened on those outgoing calls.
