Frank.Schwarz Report post Posted 04/08/2019 12:18 PM I'm trying to install the Dialogic HMP driver from VoiceGuide on a new system (hardware and virtual). A test with HPETTOOL64 is successful. Firewall, virus scanner, user account control are switched off. Installation of DialogicHMP30_Drivers_for_VoiceGuide_7.5_gen2_375 is in progress. Thereafter, however, no device is displayed in the DCM. Screenshots in the appendix. I have no idea what I can do ??? Thanks in advance!!! Dialigic HMP.pdf Share this post Link to post
SupportTeam Report post Posted 04/08/2019 12:39 PM Can you please describe the systems used in more detail. Are you certain that no other VoIP/SIP type software was previously installed on those systems? HMP and other VoIP/SIP software will usually clash. Is the virtual system a VMWare based VM ? Is the physical system a desktop/server type system? What is the CPU and OS used ? Also please note that HMP seems to have problems running on a number of notebooks. Could you maybe install VoiceGuide on those systems and then post the vgEngine traces that are created when the VoiceGuide service tries to start. the vgEngine trace will contain details of hardware used and ports open by other software etc. Share this post Link to post
Frank.Schwarz Report post Posted 04/08/2019 02:55 PM Hardware 1: Intel NUC I5-4250 8 GB RAM 64 Bit Windows 10 Pro Hardware 2: Dell Inspiron 15 7000 I7-7700 32 GB RAM 64 Bit Windows 10 Pro Hardware 3: HP Elitedesk 800 I7-4770 16 GB RAM 64 Bit Windows 8,1 Pro virtual: Microsoft Hyper-V System Hardware 3 und 1 VG log from Hardware 3 0408_1649_vgEngine.zip Share this post Link to post
SupportTeam Report post Posted 04/08/2019 08:20 PM Traces from hardware 3 show: 016 164931.925 10640 WARN HPET not enabled. Enable HPET timer and restart Windows. QueryPerformanceFrequency 536870912MHz (quad=14227720192557134) 017 164931.925 10640 WARN command to enable HPET: bcdedit /set useplatformclock true and they also show that multiple network adapters/drivers are installed on that system: 164929.071 6 Win32_NetworkAdapter Description : Intel(R) Ethernet Connection I217-LM 164929.071 6 Win32_NetworkAdapter Description : Shrew Soft Virtual Adapter 164929.086 6 Win32_NetworkAdapter Description : Apple Mobile Device Ethernet 164929.086 6 Win32_NetworkAdapter Description : Microsoft-ISATAP-Adapter 164929.086 6 Win32_NetworkAdapter Description : Apple Mobile Device Ethernet These other Ethernet driver and adapters could be causing problems for HMP. Quickest approach may be to just reformat the hard disk and then: 1. Install just Windows. 2. Confirm that Windows can communicate over the Intel I217-LM connection, 3. Enable HPET (see command quoted at top of this post) 4. Install HMP (do not install any anti-virus etc at first). When installing HMP please make sure you install as Administrator, or as a user with Administrator privileges. Dell Inspiron 15 7000 is a notebook, so would not recommend trying to install on that system. Share this post Link to post
Frank.Schwarz Report post Posted 04/12/2019 10:52 AM Hello Voice Guide Team, I think I give it up, the HMP application is useless for me. I have now tried the installation on felt 10 computers. On no computer !!! was an HMP device, as described, installed. With this difficulty, i can't install an application for a customer. Enclosed the loggings of the last computer - Dell Precision T3400 - Broadcom NetExtreme 57xx, no other networkdevices - 500 GB harddrive - 4 GB RAM - Intel Core Duo E8200 - new installed operating System WINDOWS 10 Pro - no virus scanner - Firewall off - UserAccessControl off ==> reboot pc - hpettool64 /t ==> successful - HPET enabled ==> reboot PC - DialogicHMP30_Drivers_for_VoiceGuide_7.5_gen2_375 with all Options installed ==> reboot PC ==> DCM ==> no device is shown - install VoiceGuide 7.6.5 ==> reboot if there is interest I can open on the PC a teamviewer ... then please send an email. Tanks! log.zip Share this post Link to post
SupportTeam Report post Posted 04/12/2019 11:39 AM Can you please .ZIP up this directory: C:\Program Files (x86)\Dialogic\HMP\log and post the .ZIP file here. Dialogic's own log files may let us see what is happening on this system. Share this post Link to post
SupportTeam Report post Posted 04/12/2019 12:03 PM Also, do you have access to a system running VMware ESXi? HMP supports running on VMware ESXi VM instances, and using VMs allows a fast way to create environments into which Dialogic HMP can be installed. VMware ESXi would be providing a pretty 'standard' environment for HMP to install into. Share this post Link to post
Frank.Schwarz Report post Posted 04/12/2019 12:30 PM Attached the dialogic zip. I don't use VMWare and have no way to access VMWare. I only could use Hyper-V from Microsoft. log.zip Share this post Link to post
SupportTeam Report post Posted 04/14/2019 08:07 AM Please do this: 1. Stop the VoiceGuide service. 2. Stop the Dialogic service. Please place the attached RtfConfigWin.xml file on your system - unzip attached file first. (file link at very bottom of this post) for Windows Server 2008 R2 and newer: 3a. make the hidden directory C:\ProgramData visible 3b. go to C:\ProgramData\Dialogic\HMP\cfg for older versions of windows and Server 2008 32bit : 3a. go to C:\Program Files\Dialogic\cfg Then: 4. Backup existing RtfConfigWin.xml, 5. Replace it with attached RtfConfigWin.xml (unzip it first) 6. Shutdown and restart Windows. 8. Start the Dialogic service from DCM 9. Once Dialogic service has fully started .ZIP up Dialogic RTF logs in Dialogic's \log\ subdirectory. 10. Please post all the above logs here. RtfConfigWin.zip Share this post Link to post
SupportTeam Report post Posted 04/24/2019 10:34 AM HMP does not work on many notebooks. There are also reports of problems running on lower end DELL PCs. Seems to be related to the way in which the networking hardware is designed on those systems Share this post Link to post
Frank.Schwarz Report post Posted 04/24/2019 02:09 PM Sorry it took so long. Attached the desired log. in the Zip-File i have attached a screenshot from DCM. Thanks! log.zip Share this post Link to post
SupportTeam Report post Posted 05/03/2019 07:44 AM RTF Logs do not actually show much information as to why the "HMP" device was not activated on your system. Attaching RTF log from working system for comparison. You can see that in trace from problem system we see Dialogic not being able to get some configuration information from what is most likely the network drivers or their saved config data on the system. And before that some initialization steps are just missing from that log, without explanation. So these logs do not seem to indicate actual cause of problem. As per prior answer there are reported issues of problems installing HMP on some notebooks, so those same issues may be seen on cheaper grade consumer hardware. If you do not have access to 'Server' grade hardware then can you maybe just getting a 'Strandard' PC with an ASUS or Gigabyte etc, motherboard and try using that? Log excerpt from supplied trace: 04/24/2019 15:53:58.598 4892 6984 OAMSYSLOG Info MERCCONFIG - Calling GetBoardData() for board 0 04/24/2019 15:53:58.598 4892 6984 OAMSYSLOG Info MERCCONFIG - IOCTL_MCD_GET_MPD_CONFIG_DATA returned error 2 04/24/2019 15:53:58.598 4892 6984 OAMSYSLOG Info MERCCONFIG - MC_ERROR_ENUM exception of value 17 is caught 04/24/2019 15:53:58.598 4892 6984 OAMSYSLOG Info MERCCONFIG - GetBoardData failed for board 0 04/24/2019 15:53:58.598 4892 6984 OAMSYSLOG Info MERCCONFIG - Freeing PNP library in mercconfig DetectBoards 04/24/2019 15:53:58.598 4892 6984 OAMSYSLOG Info MERCCONFIG - CPCIDetector::Detect() returning 0 devices 04/24/2019 15:53:58.598 4892 6984 OAMSYSLOG Info MERCCONFIG - Leaving the MCEnumDetectedBoardsEx, count = 0 04/24/2019 15:53:58.598 4892 6984 OAMSYSLOG Info NCMAPI - Calling AddDevices() for DM3 devices 04/24/2019 15:53:58.598 4892 6984 OAMSYSLOG Info NCMAPI - Entering AddDevices() 04/24/2019 15:53:58.598 4892 6984 OAMSYSLOG Info NCMAPI - AddDevices(), calling ConfigDevices() 04/24/2019 15:53:58.598 4892 6984 OAMSYSLOG Info NCMAPI - NCMAPI.. in ConfigDevices().Family - DM3, calling GetInstalledDevices() 04/24/2019 15:53:58.598 4892 6984 OAMSYSLOG Info NCMAPI - ConfigDevices()(), InstalledDevice list is NULL, return Compare to log trace from a system where HMP works OK. (BTW. trace is from a Lenovo T-Series Thinkpad running Win10) 05/03/2019 15:03:24.111 3444 10428 OAMSYSLOG Info MERCCONFIG - Calling GetBoardData() for board 0 05/03/2019 15:03:24.140 3444 10428 OAMSYSLOG Info MERCCONFIG - Model Number returned by driver = 32809 05/03/2019 15:03:24.140 3444 10428 OAMSYSLOG Info MERCCONFIG - Freeing PNP library in mercconfig DetectBoards 05/03/2019 15:03:24.140 3444 10428 OAMSYSLOG Info MERCCONFIG - CPCIDetector::Detect() returning 1 devices 05/03/2019 15:03:24.140 3444 10428 OAMSYSLOG Info MERCCONFIG - Leaving the MCEnumDetectedBoardsEx, count = 1 05/03/2019 15:03:24.141 3444 10428 OAMSYSLOG Info NCMAPI - Calling AddDevices() for DM3 devices 05/03/2019 15:03:24.141 3444 10428 OAMSYSLOG Info NCMAPI - Entering AddDevices() 05/03/2019 15:03:24.141 3444 10428 OAMSYSLOG Info NCMAPI - AddDevices(), calling ConfigDevices() 05/03/2019 15:03:24.141 3444 10428 OAMSYSLOG Info NCMAPI - NCMAPI.. in ConfigDevices().Family - DM3, calling GetInstalledDevices() 05/03/2019 15:03:24.141 3444 10428 OAMSYSLOG Info NCMAPI - ConfigDevices(), InstalledDevice list is not NULL, compare the serial number rtf_log_working_system.zip Share this post Link to post
