Guest SS Report post Posted 03/22/2004 04:35 PM I have D41ESC ISA, everythink OK (dialtone, disconnect) , but there is a problem with onconnect When I am dialing for examle 2109767, after some rings system says onconnected, but on other side nobody answer. What to do that this onconnected work well and means true? Share this post Link to post
SupportTeam Report post Posted 03/23/2004 01:06 AM Could you please post a copy of VoiceGuide's Debug Printout which captures the call, this will allow us to see what is happening. (When running the script click on VoiceGuide's View menu and select 'Event Trace Log' option - any log information will then appear in this window. You must open the trace window before making the call) Share this post Link to post
Guest SS Report post Posted 03/24/2004 08:44 AM Here it is what I see: etLine1.Device.ID := 5 etLine1.Device.Active := True Dialing [w02109769] >>>here 0 is outgoing digit from PBX<<<< etLine1.OnCallBegin etLine1.OnDialtone etLine1.OnCallerID CallerID.Name = CallerID.Number = 370-698-13757 etLine1.OnDialing etLine1.OnCalledID CalledID.Name = CalledID.Number = L02-109-769 >>>what dialed dialogic<<<< etLine1.OnConnected >>> this must be after other sides answer, but appears before answer<<< Check for automated device etLine1.Call.MonitorSilence.Active := True etLine1.OnSilence Silence detected in less than 3 seconds Likely a human Hangup >>>made by myself, in other case ringing gois to continues <<< Share this post Link to post
SupportTeam Report post Posted 03/24/2004 10:34 AM You are using some other software.... not VoiceGuide... If you want to get outbound dialing going I'd recommend downloading and installing VoiceGuide and then using the Telephone Number Loader program which comes with VoiceGuide to queue the outgoing calls. VoiceGuide can detect correctly when the call is answered and can distinguish whether a live human or an answering machine answered the call. To download and install a fully working evaluation version of VoiceGuide see: http://voiceguide.com/vgDownload.htm Share this post Link to post
Guest SS Report post Posted 03/24/2004 04:14 PM Thank YOU! With voiceguide it works perfect! Share this post Link to post
