Lukas Report post Posted 10/10/2019 07:46 AM Hi, We have a problem with voiceguide vgEngine : 7.5.21 - 7.5.6739.39172 when VG start no available port. The cart is Dialogic is start but the VG dosn't available port. The status monitor is empty. Share this post Link to post
SupportTeam Report post Posted 10/10/2019 07:58 AM Please .ZIP up VoiceGuide's trace files from today and post them here. We can then see what is happening on the system and advise. The trace files can be found in VoiceGuide's \log\ subdirectory. Share this post Link to post
SupportTeam Report post Posted 10/10/2019 09:33 AM This system has two cards installed in it: a D/300JCT-E1 (FX033865) and a D/600JCT-2E1 (HQ014394) Are the two cards connected together with a CT cable? ktTel trace shows error as: 349 104500.770 3772 ERROR gc_OpenEx :N_dtiB1T1:P_ISDN returned linedev<=0. Check DCM to confirm ISDN protocol has been selected on this trunk. Has ISDN Protocol been set on the trunks? What has it been set to? Share this post Link to post
SupportTeam Report post Posted 10/10/2019 09:44 AM Dialogic RTF logs may show more information. Dialogic RTF logs can be found in Dialogic's \log\ subdirectory. Share this post Link to post
Lukas Report post Posted 10/10/2019 01:39 PM 4 hours ago, SupportTeam said: This system has two cards installed in it: a D/300JCT-E1 (FX033865) and a D/600JCT-2E1 (HQ014394) Are the two cards connected together with a CT cable? ktTel trace shows error as: 349 104500.770 3772 ERROR gc_OpenEx :N_dtiB1T1:P_ISDN returned linedev<=0. Check DCM to confirm ISDN protocol has been selected on this trunk. Has ISDN Protocol been set on the trunks? What has it been set to? Yes the cards are connected together. ISDN work to 23:10 yesterday when we shutdown the serwer and up the VG didn't see the port. Share this post Link to post
Lukas Report post Posted 10/10/2019 01:45 PM the log from dialogic dial-log.zip Share this post Link to post
SupportTeam Report post Posted 10/10/2019 09:19 PM The Dialogic RTF log files are not for the same time as the supplied ktTel traces, so we cannot co-relate them. Please do a VoiceGuide service restart again and then .ZIP up bot the ktTel and RTF traces after the restart attempt completes and post them here. We canthen see what RTF log is showing when VoiceGuide attempts to open the channels. Was anything installed/changed on this server that necessitated the server restart? Any Windows patches etc? Why was that server restarted? Also, traces show that this system is running Windows 7. Would recommend moving system to a newer version of Windows, preferably a 'Server' grade version. Share this post Link to post
Lukas Report post Posted 10/10/2019 09:47 PM New logs attached. server was reset because it had no power. As for the system, it has been used since the beginning. There was no windows update dialogic.zip VG.zip Share this post Link to post
SupportTeam Report post Posted 10/11/2019 12:00 AM ktTel trace shows Dialogic drivers returned error when trying to open the port: 403 233834.555 3420 gc_OpenEx :N_dtiB1T1:P_ISDN call 404 233842.560 3420 ERROR gc_OpenEx :N_dtiB1T1:P_ISDN returned linedev<=0. Check DCM to confirm ISDN protocol has been selected on this trunk. And Dialogic traces show: 10/10/2019 23:38:42.560 2104 3420 spwrndi ERR1 ndi dtiB1 ====> NdiSendMessageAndWait: Timed out waiting for response for NRB Request (0x20001) 10/10/2019 23:38:42.560 2104 3420 libisdnr..ll dtiB1 ERR1 dtiB1 ----> IsdnGetNetType(LineDev:1) returns: 0x3 due to (SrlSendAtomicRequestAndWait failed) 10/10/2019 23:38:42.560 2104 3420 libisdnr..ll dtiB1 ERR1 dtiB1 ----> IsdnOpen() returns:-1 due to (IsdnGetNetType() failed) 10/10/2019 23:38:42.560 2104 3420 spwrgcis ERR1 gcis dtiB1T1 ::::> gcis_alarmdb_insert() returns -1 due to cc_Open(dtiB1) failed 10/10/2019 23:38:42.560 2104 3420 spwrvoice ERR1 dxmain ==<== GetValidDeviceInfo(): SrlGetDeviceInfo() failed! returns NULL 10/10/2019 23:38:42.560 2104 3420 spwrvoice ERR1 dxmain ==<== GetValidDeviceInfo(): SrlGetDeviceInfo() failed! returns NULL 10/10/2019 23:38:42.560 2104 3420 spwrvoice ERR1 dxmain <==== dx_set_lasterr(SrlDevice 0, NewError 7): GetValidDeviceInfo() failed! returns -1 10/10/2019 23:38:42.560 2104 3420 spwrvoice ERR1 dxmain ==<== GetValidDeviceInfo(): SrlGetDeviceInfo() failed! returns NULL 10/10/2019 23:38:42.560 2104 3420 spwrvoice ERR1 dxmain ==<== GetValidDeviceInfo(): SrlGetDeviceInfo() failed! returns NULL 10/10/2019 23:38:42.560 2104 3420 spwrvoice ERR1 dxmain <==== dx_set_lasterr(SrlDevice 0, NewError 7): GetValidDeviceInfo() failed! returns -1 It loos like Dialogic drivers cannot see some internal configuration setting (Dialogic's own logs show the internal function "IsdnGetNetType" returning a fail). Was the "no power" event an abrupt power disconnect type situation that did not allow for orderly system shutdown? Currently are only the Green colour LEDs on the back of the card lit? (The LEDs next to the RJ connector where the E1 trunks are plugged in) Or are there some other colour LEDs lit up as well now? Recommend stopping VoiceGuide and Dialogic services and using DCM to "Restore Device Defaults" for each card and then going through the relevant settings in the Dialogic DCM and setting them to correct trunk types and ISDN protocols. Share this post Link to post
Lukas Report post Posted 10/11/2019 08:32 AM Hi, ok I checked the parameters on another card and the current one has lost one parameter. Thank you for your help Share this post Link to post
