Guest u4910 Report post Posted 10/24/2019 02:37 PM I'm having an issue where the script just hangs up instead of going back to a module to get correct input. When I get input, I pass it to a database lookup. It selects count(*) so that I can see if it is a correct value. Then I evaluate it in a module to determine to move to next module or repeat getting digits for a correct account number. ($RV[DB_CUST_CHECK_RowCount])>0 On a value that returns 0 records "121212" it seems to just hang up here 101618.269 On a good value it goes to the next module 101639.261 101639.290 Here are the paths in the Evaluate function (Prem is the next module; Cust - repeate because of bad account number): on {true} goto [Prem] on {false} goto [Cust] on {timeout} goto [Cust] Am I doing something wrong on the evaluation? 1024_1014_vgEngine.txt Share this post Link to post
SupportTeam Report post Posted 10/24/2019 05:54 PM The hangup at 101618.323 is in the Database Query module. Not in the Evaluate Expression module. If the SQL query returns no rows or the scalar count returned is 0 (ie: no rows) then the Database Query module will take the "on {fail} goto ..." or the "on {false} goto ..." path. Try adding on {false} goto [your_eval_module] or an on {fail} goto [your_eval_module] to your Database Query module. Or you can just put the paths from the Evaluate Expression module into the Database Query module: on {true} goto [Prem] on {false} goto [Cust] on {timeout} goto [Cust] the Database Query module will then go direct to [Prem] if RowCount>0 or [Cust] if RowCount=0 (or timeout) Share this post Link to post
Guest u4910 Report post Posted 10/24/2019 06:20 PM OK, that worked. I moved the on true/false to the database module. Thanks. Share this post Link to post
SupportTeam Report post Posted 10/24/2019 10:16 PM btw. This path is not correct: on {timeout} goto [Cust] It is missing the timeout value. Should be something like this on {timeout 5} goto [Cust] Share this post Link to post
