Guest u4910 Report post Posted 01/07/2020 05:26 PM When generating wav files via text to speech, the same file that gets reused sometimes gets a file lock and the new wav file fails to generate. Have to stop VG service and clear the wav files from temp folder to ensure new files get generated. Share this post Link to post
SupportTeam Report post Posted 01/07/2020 09:48 PM VoiceGuide should set a new unique filename as the file to save the TTS stream to in cases where it cannot access/open/overwrite existing file. Can you please post the vgEngine, ktTel and ktTts traces for the time when this problem occurred and we can the see what happened on the system and advise. Share this post Link to post
SupportTeam Report post Posted 01/08/2020 03:59 AM The vgEngine trace from the system showed a number of "There is not enough space on the disk." errors between 8:10 and 9:15 And no more such errors between 9:15 and when the vgEngine trace ended at 15:21 No space on disk would prevent new TTS stream save files from being created. Was the TTS problem resolved at just after 9:15 ? The ktTts and ktTel logs would show more information, so if you can forward those we can better comment on what happened on this system. Line 387: 081028.294 8 ERROR v7.6.17 - 7.6.7285.40796 (2019-12-12 22:39:50.66) TimerCountDown_1Sec : There is not enough space on the disk. Line 412: 081029.316 7 ERROR v7.6.17 - 7.6.7285.40796 (2019-12-12 22:39:50.66) TimerCountDown_1Sec : There is not enough space on the disk. Line 444: 081528.265 32 ERROR v7.6.17 - 7.6.7285.40796 (2019-12-12 22:39:50.66) TimerCountDown_1Sec : There is not enough space on the disk. Line 469: 081529.228 8 ERROR v7.6.17 - 7.6.7285.40796 (2019-12-12 22:39:50.66) TimerCountDown_1Sec : There is not enough space on the disk. Line 501: 083028.288 8 ERROR v7.6.17 - 7.6.7285.40796 (2019-12-12 22:39:50.66) TimerCountDown_1Sec : There is not enough space on the disk. Line 526: 083029.318 3 ERROR v7.6.17 - 7.6.7285.40796 (2019-12-12 22:39:50.66) TimerCountDown_1Sec : There is not enough space on the disk. Line 1196: 084348.265 42 ERROR v7.6.17 - 7.6.7285.40796 (2019-12-12 22:39:50.66) TimerCountDown_1Sec : There is not enough space on the disk. Line 1221: 084349.206 42 ERROR v7.6.17 - 7.6.7285.40796 (2019-12-12 22:39:50.66) TimerCountDown_1Sec : There is not enough space on the disk. Line 1258: 084528.318 3 ERROR v7.6.17 - 7.6.7285.40796 (2019-12-12 22:39:50.66) TimerCountDown_1Sec : There is not enough space on the disk. Line 1283: 084529.311 3 ERROR v7.6.17 - 7.6.7285.40796 (2019-12-12 22:39:50.66) TimerCountDown_1Sec : There is not enough space on the disk. Line 1359: 085031.332 8 ERROR v7.6.17 - 7.6.7285.40796 (2019-12-12 22:39:50.66) TimerCountDown_1Sec : There is not enough space on the disk. Line 1514: 090020.284 7 ERROR v7.6.17 - 7.6.7285.40796 (2019-12-12 22:39:50.66) TimerCountDown_1Sec : There is not enough space on the disk. Line 2193: 090033.228 7 ERROR v7.6.17 - 7.6.7285.40796 (2019-12-12 22:39:50.66) TimerCountDown_1Sec : There is not enough space on the disk. Line 2287: 090034.273 7 ERROR v7.6.17 - 7.6.7285.40796 (2019-12-12 22:39:50.66) TimerCountDown_1Sec : There is not enough space on the disk. Line 2733: 090051.469 18 ERROR v7.6.17 - 7.6.7285.40796 (2019-12-12 22:39:50.66) CallEvents_DumpToFile : There is not enough space on the disk. Line 3054: 090103.256 8 ERROR v7.6.17 - 7.6.7285.40796 (2019-12-12 22:39:50.66) TimerCountDown_1Sec : There is not enough space on the disk. Line 3999: 090201.270 32 ERROR v7.6.17 - 7.6.7285.40796 (2019-12-12 22:39:50.66) TimerCountDown_1Sec : There is not enough space on the disk. Line 4072: 090212.246 8 ERROR v7.6.17 - 7.6.7285.40796 (2019-12-12 22:39:50.66) TimerCountDown_1Sec : There is not enough space on the disk. Line 4271: 090234.278 8 ERROR v7.6.17 - 7.6.7285.40796 (2019-12-12 22:39:50.66) TimerCountDown_1Sec : There is not enough space on the disk. Line 4598: 090305.320 8 ERROR v7.6.17 - 7.6.7285.40796 (2019-12-12 22:39:50.66) TimerCountDown_1Sec : There is not enough space on the disk. Line 5123: 090333.811 18 ERROR v7.6.17 - 7.6.7285.40796 (2019-12-12 22:39:50.66) WriteCDRlogs AppendAllText : There is not enough space on the disk. Line 5681: 091528.265 3 ERROR v7.6.17 - 7.6.7285.40796 (2019-12-12 22:39:50.66) TimerCountDown_1Sec : There is not enough space on the disk. Line 5706: 091529.309 8 ERROR v7.6.17 - 7.6.7285.40796 (2019-12-12 22:39:50.66) TimerCountDown_1Sec : There is not enough space on the disk. Share this post Link to post
Guest u4910 Report post Posted 01/08/2020 03:46 PM Makes sense. I will do further testing and monitor disk space and see if it happens again when there is available space. Share this post Link to post
