Guest Ada Report post Posted 06/02/2020 07:13 AM I would like to ask that can I create Result Variable by myself? It is because I need it to have a unique id for each call from its beginning to end (using when jumping to other sub-call-flow/script project or calling backend program/api ) Share this post Link to post
SupportTeam Report post Posted 06/02/2020 07:23 AM Yes. Simplest way to create/set a Result Variable is by using an Evaluate Expression module: https://www.voiceguide.com/vghelp/source/html/modevalexpr.htm Many peopl use the $RV_LINEID and $RV_PORT and the Date/Time $RVs ($RV_YY, $RV_MM, $RV_DD, $RV_HH, $RV_NN $RV_SS etc) to create a unique expression which is the used as the 'Call ID' and save that expression to new $RV. eg: Put this in the Evaluate Expression module as the expression to evaluate "$RV_YY$RV_MM$RV_DD$RV_HH$RV_NN$RV_SS_$RV_PORT" and put this in the "Assign result to the following Result Variable: my_call_id you will then be able to use: $RV[my_call_id] for rest of script running during the call. Other ways of setting $RVs is by calling the API functions: https://www.voiceguide.com/vghelp/source/html/com_rvset.htm https://www.voiceguide.com/vghelp/source/html/com_rvset_rvlist.htm You can also create/set a list of $RVs when using "Run_ResultReturn" API call when returning from JavaScript/VBScript call: https://www.voiceguide.com/vghelp/source/html/com_run_resultreturn.htm And the Script_Goto / Script_Gosub / Script_Return API calls: https://www.voiceguide.com/vghelp/source/html/com_script_goto.htm https://www.voiceguide.com/vghelp/source/html/com_script_gosub.htm https://www.voiceguide.com/vghelp/source/html/com_script_return.htm Share this post Link to post
Guest Ada Report post Posted 06/02/2020 08:21 AM Thank you. I would like to ask that should the Evaluate Expression module put before a play module or after play module (Greeting module)? It is because after greeting module, I need to let user to select language. Share this post Link to post
SupportTeam Report post Posted 06/02/2020 08:29 AM You can put it before or after. There is no noticeable delay when running a Evaluate Expression module (it takes a few milliseconds to run), so it will not make any difference. Share this post Link to post
SupportTeam Report post Posted 06/02/2020 08:30 AM BTW. Here is a Help file section that has some notes on one approach to creating multi-language systems: https://www.voiceguide.com/vghelp/source/html/multi-language.htm Share this post Link to post
Guest Ada Report post Posted 06/08/2020 04:47 AM I would like to ask why I can't use the Evaluate Expression module's result Variable for run VBScript. Please refer to the attachment. Share this post Link to post
SupportTeam Report post Posted 06/08/2020 04:57 AM That should work. Can you please post the vgEngine trace file so we can see what happened on the call. The vgEngine trace file is created in VoiceGuide's \log\ subdirectory. Please .ZIP up the trace file before posting. Share this post Link to post
Guest Ada Report post Posted 06/08/2020 05:10 AM Please refer to the attachment. Thank you. 0608_1300_vgEngine.zip Share this post Link to post
SupportTeam Report post Posted 06/08/2020 05:26 AM The module "Call_id" is not part of the active call flow. Have you set the starting module correctly? Here are the modules that the callflow on your system goes through during the call: 130122.464 16 3 1 1 state [Greeting] tts generate start (len=65) | 130122.583 16 3 1 1 state [Greeting] Playing tts (C:\Program Files (x86)\VoiceGuide\temp\tts_3_1.wav) | 130124.884 16 3 1 1 state [OutPutCallId] RunScript | 130124.906 28 3 1 1 state [OutPutCallId] RunScript vbs, onhold= | Share this post Link to post
SupportTeam Report post Posted 06/08/2020 05:28 AM The "Starting Module" of the script is set in the "Edit" -> "Script Properties" menu in the VoiceGuide Script Designer. Share this post Link to post
