Guest Ada Report post Posted 06/10/2020 07:44 AM I would like to ask does the result variable can take on a 4 digit value of current year in result variable such as 2020? It is because I need to use it for the call flow script. I know that it can take 2 digit value currently ( $RV_YY) Share this post Link to post
SupportTeam Report post Posted 06/10/2020 09:33 AM This $RV is replaced with a 4 digit year: $RV_YEAR or you can use this expression: 20$RV_YY after $RV_YY is replaced the resulting string will be: 2020 Share this post Link to post
