Result Variable shows which channel is using
I would like to ask whether Result Variable can show which channel is using? I need to using it in log text file.
From https://www.voiceguide.com/vghelp/source/html/resultvariables.htm :
$RV_PORT
Line Device's position is VoiceGuide's line status listing. Numbering starts from the top, with first line/port having a $RV_PORT of 1, the second line/port having a $RV_PORT of 2, etc.
$RV_LINEID
Identification number of the line device which is handling this call. The ID number refers to an internal line ID number - not the position in which that line's status is displayed in VoiceGuide's status window.
