Guest Ada Report post Posted 06/18/2020 08:57 AM I would like to ask can VoiceGuide generate dynamic voice for the call-flow by using script program? It is because one of the staff set up a TTS engine on the webpage. Share this post Link to post
SupportTeam Report post Posted 06/18/2020 09:07 AM Yes. There are a number of different ways of doing this. Common approach is to assign the text of what is to be played to a Result Variable, and use that variable in the text sent to TTS engine. Or you can have some external process generate/prepare the sound file to be played and VoiceGuide can play it (filename can be pre-determined, or assigned to $RV and that $RV used as part of the filename expression in the 'sound file to play' for the module. There are other approaches. If you can post the script showing what you need to do then we can better advise. Share this post Link to post
