D.H. Report post Posted 06/29/2020 03:32 PM Hi Support, I have created a call-flow which will call external PHP program. I worked before, however, do know why it suddenly not working, the call flow will hang every time when it goes into the node for calling the program, attached is the screen capture of the node. I tried to restart the IVRS/PC, but still not working. I am quite sure the php is fine, as I can call it via cmd line and event create very simple program (just echo something then exit), the call-flow still hang there. It seems like the IVRS cannot trigger the program at all. Please advise how can I troubleshoot or fix it. below is the command I used to call the PHP program: C:\wnmp\php-7.4.7\php -f C:\wnmp\WWW\public\voiceguide\Main\script\gen_balance.php $RV[Input member ID] $RV[Get Lang] share Share this post Link to post
D.H. Report post Posted 06/29/2020 04:27 PM I checked the log and found that now seems the voice guide cannot create process for the PHP script, however, previously it is fine. You can compare the screen capture of current failure case and previous success case. Share this post Link to post
SupportTeam Report post Posted 06/30/2020 12:31 AM Has the Windows' Event Viewer logged any errors when at the 23:47:42 time? In Windows' Event Viewer please go to "Windows Logs" -> "Application" and see if any error events were logged at that time. Then please click on the error entry to show the details, and post screenshots of the details showing. Share this post Link to post
SupportTeam Report post Posted 06/30/2020 12:33 AM Can you also please post the full vgEngine trace as well. We can then better see what is happening on the system. Please .ZIP up any traces before posting. Share this post Link to post
D.H. Report post Posted 06/30/2020 01:43 PM Hi Support, Please find the screen capture of the application event. Also the trace log is attached for your investigation. I retested again and at "213443.451" the call is into the run program node then hang. Please check and advise. 0630_2132_vgEngine.zip Share this post Link to post
SupportTeam Report post Posted 07/01/2020 12:29 AM This would be caused by Anti-Virus software blocking VoiceGuide from starting external programs. Please ensure the Antivirus software is set to not interfere with VoiceGuide, or the Antivirus software is disabled. Share this post Link to post
