Detect the numbers of rings in VoiceGuide
I would like to ask how to detect the numbers of rings in VoiceGuide? It is because I need to know the times of ring. If the call is not answered within 3 rings, the Voiceguide should treat the call result as not answered. Thank you
This is on outgoing calls, yes?
You can set the maximum time that the system will wait for an outgoing call to be answered.
There is an "AnswerTimeout" setting that can be used on Dialer calls.
On call transfers a "timeout" type path is used, and that path is taken when the call is not answered within the specified time.
