automatic call recording?
I found in logs:
2-line record not started. record file not specified
how to use this?
In "Dial and Conference's" "Options" you can specify the sound file to record both sides of the bridged/tromboned call to.
This is done using the "<record2lines>" XML notation. eg:
<record2lines>C:\MyDirectory\MyFile.wav</record2lines>
you can also specify just the directory, in which case the filename will be be automatically generated.
<record2lines>C:\MyDirectory\</record2lines>
This option is not documented at this stage, may not handle edge cases well, and it might change in the future.
