Excel Macro
Is it possible to execute an Excel macro?
My DDE command is as follows:
Topic: Excel|Sheet1
Item: <blank>
"Execute Command" selected
Command: [Run(FindPrefix$RV_LINEID)]
I've also tried:
Command: [Activate(FindPrefix$RV_LINEID)]
Not too sure how to invoke Excel macros via Excel's DDE interface - best to look into Excel manuals on this one...
You may want to look into using the Run VB Script module to control Excel via it's COM interface. There are some examples in VG Help file:
The VB Script below saves information to an Excel spreadsheet.
Dim xlApp, xlBook, xlSht
Dim filename, value1, value2, value3, value4
on error resume next
filename = "c:\warehouse.xls"
Set xlApp = CreateObject("Excel.Application")
set xlBook = xlApp.WorkBooks.Open(filename)
set xlSht = xlApp.activesheet
xlApp.DisplayAlerts = False
'write data into the spreadsheet
xlSht.Cells(2, 2) = "New Data"
xlBook.Save
xlBook.Close SaveChanges=True
xlApp.Close
xlApp.Quit
'always deallocate after use...
set xlSht = Nothing
Set xlBook = Nothing
Set xlApp = Nothing
