cargoms Report post Posted 06/10/2021 08:29 AM Dear Support Our Procedure #1 First Try Insta;ll Card, Donwload SR275, Voice Guide, after install, Dialogic Card Can not Detect #2 Second Try Check with Card Supplier, get the most latest SR280 from a diff download from https://wiki.freepbx.org/display/DVC/JCT+Software+Update+-+Sangoma+System+Release+6.0+PCI+Windows Installed, Dialogic DCM can detect and started Install VoiceGuide, but face a error msg: Dialogic Driver Not Found Kindly help on the issue, log file attached Kevin cargo-vg-log.zip Share this post Link to post
SupportTeam Report post Posted 06/10/2021 12:38 PM Did you reboot the machine after installing the SR275 drivers? Can you advise the model of the Dialogic card used? Share this post Link to post
SupportTeam Report post Posted 06/10/2021 01:14 PM Also, can you advise the full "OS Build" version of Windows. This can be found in Windows' Settings->System->About page, in the "Windows specifications" section. Share this post Link to post
cargoms Report post Posted 06/11/2021 07:39 AM Dear Support Thanks so much for the guide OS Build (win10 pro): 19042.1052 Card Model: SANGQMA, D4PCIUFEQ Thanks Kevin Share this post Link to post
SupportTeam Report post Posted 06/11/2021 09:37 AM (edited) Please try using this VoiceGuide version: [old link removed] the above version should work with SR280. Please see the below instructions. If you encounter any issues please post the latest traces file from VoiceGuide's \log\ subdirectory. This way we can see what is happening on the system. Please .ZIP up all the traces before posting them. Updating VoiceGuide To update to newer version of VoiceGuide: 1. Stop VoiceGuide Service. VoiceGuide Service can be stopped by clicking on the VoiceGuide Service Monitor in the Windows's Icon Tray on bottom right of the taskbar and selecting "Stop". 2. Exit all VoiceGuide programs. This includes the Service Monitor applet in the Icon Tray area in bottom right of the screen, as well as the Script Designer, Line Status Monitor, etc. 3. Run the VoiceGuide install and install into same directory as existing installation. (Do NOT uninstall the previous VoiceGuide installation). 4. Start VoiceGuide service. Note: Running a VoiceGuide install over the top of an existing install will NOT overwrite existing configuration or license files (Config.xml, ConfigLine.xml, VG.INI, etc) and will not remove any of users script or sound files, and will not remove any log files etc. Edited 12/09/2022 04:24 AM by SupportTeam Share this post Link to post
cargoms Report post Posted 06/12/2021 04:41 AM Dear Support I follow the instruction, all works, I did brand new installation Thanks very much Kevin Share this post Link to post
