Guest vrmaniac Report post Posted 03/15/2003 11:11 PM 03546 0 Email (SMTP) send start 1 email@yar.com 03546 0 smtp SendFailed Missing or Invalid Sender E-mail Address Missing or Invalid Recipient E-mail Address all fields are filled in. smtp server 192.168.1.1 return email address exists. Share this post Link to post
SupportTeam Report post Posted 03/16/2003 01:09 AM Please post your script (just the .vgs file) and we can have a look at it, which version of VoiceGuide are you using? Share this post Link to post
Guest vrmaniac Report post Posted 03/16/2003 02:05 AM It must have had something to do with the placement, i moved the module from the 2nd thing run to the first and it works fine now. Thanks anyway Share this post Link to post
SupportTeam Report post Posted 03/16/2003 02:48 AM Will the problem still occur when you move the module back to being the 2nd? If you find that the problem still occurs then please let us know. Share this post Link to post
Guest vrmaniac Report post Posted 03/16/2003 06:24 AM No it still was not working, it just scrolled the error quicker heh. I did manage to debug the issue, its where your application verifies the address in the field is valid by looking for .com extension, problem is i use a .biz I even tried a ip address with out sucess. When i changed the email address to my old yahoo.com address it worked fine. Share this post Link to post
Guest vrmaniac Report post Posted 03/17/2003 10:45 PM Any patch on the way yet? Share this post Link to post
SupportTeam Report post Posted 03/22/2003 10:32 PM v4.9 (out in about a week) will no longer check what has been specified in the 'return email address' field. Share this post Link to post
Guest Rodney Report post Posted 04/26/2003 03:17 PM Now with version 4.9 I can not get voice guide to retain the SMTP settings that I enter into the SMTP settings field on the EMAIL tab of VoiceGuide Voicemail Manager dialog. Share this post Link to post
SupportTeam Report post Posted 04/29/2003 12:35 AM The attached new Voicemail manager fixes this. VgVmMgr_4.9.0_INI_fix.zip Share this post Link to post
