Send Pager Message Block
How do I use the 'send pager message' block in a script as a callout function? I want to be able to activeate this block if an alarm occcurs in a monitoring syste.
Mike.
When the module is executed it will just insert an entry in the OutDialQue.mdb database in VG's \data\ subdirectory, and then VG Dialer will place the call and deliver the pager message.
You can of course insert the entry into the OutDialQue.mdb yourself, and as soon as the entry is placed there VG Dialer will make the call. you need to use "DIAL_PAGER_NUMERIC" for the sScript and sAnswerMachineMsg fields.
You can use VG's Dialer_OutDialQueAdd COM function to do the insert as well - here is an example of the VB Script to run:
vg.Dialer_OutDialQueAdd "0,5551234", 0, 0, 0, "", "", "123456789", "DIAL_PAGER_NUMERIC", "DIAL_PAGER_NUMERIC", "", 0, 2, 5, ""
set vg = Nothing
Where "123456789" is the pager message and "0,5551234" is the telephone number to dial.
Just place the quoted script into a file with a suffix of ".vbs" and then to run the VB Script run this command:
Wscript myname.vbs
The VB Script will then be ran...
