Oliver Report post Posted 08/23/2021 11:49 AM Hello, My company has been using VoiceGuide with a 4-line Professional Version license, I was asked to develop a script to read from a text file and proceed depending on the values of the file. I took an example script that resides on "OpenClosedOrHolidays" project in the VoiceGuide directory, I made some changes to adapt it to our necessities. For testing, I used the DIALOGIC HMP driver and installed VoiceGuide as VOIP service, once developed, installed and tested the script ran all right. Now when I tried installing the same script on the PC hosting the VoiceGuide with the license, the script wouldn't run, it would just stay "On Hold". One difference I can mention is that this PC is running VoiceGuide 4 and with a dialer service, meaning I can call it from a Phone. Can you help me understand why this happens and if there’s anything I can do to make it work? This is the Call_Event log I get when I call: { "call": { "crn": "1000000a", "port": "2", "direction": "in", "time_start": "2021-08-23 11:15:42", "events": " 111541.996|callstate|DE_RINGS|||||0|2|8|0 111541.997|event|DE_RINGS|||||2|0|8|0 111541.998|event|EV_RING|||||1|0|0|0 111541.998|command|cmd_AnswerCall|||||0|0|0|0 111541.999|event|TDX_CST|DE_RINGS|ET_RON|||0|0|0|0 111542.546|event|TDX_SETHOOK|DX_OFFHOOK|CALL_INBOUND|||0|0|0|0 111542.546|callstate|TDX_SETHOOK_DX_OFFHOOK|||||0|256|4|0 111542.547|state|Ring 1 connected|||||0|0|0|0 111542.549|state|[Clear retries counter] Evaluate [0]|||||0|0|0|0 111542.551|state|[Welcome] Playing wav (C:\Program Files\VoiceGuide\Scripts\Vac\Wav\welcome.wav)|||||0|0|0|0 111542.551|event|TDX_SETHOOK_DX_OFFHOOK|||||256|1|4|0 111542.551|command|cmd_PlayStart|||||117366|0|0|0 111542.551|event|TDX_CST|DE_LCON||||3189|0|0|0 111545.068|state|[Check System Online] RunScript vbs, onhold=|||||0|0|0|0 111600.212|event|FAX|DE_TONEON|FAX|||1005|0|0|0 111600.213|event|TDX_CST|DE_TONEON|FAX|||1005|0|0|0 111603.789|event|DISCONNECT|DE_TONEON|DISCONNECT_USER_2|||1004|0|0|0 111603.789|event|DISCONNECT_USER_2|DE_TONEON|DISCONNECT_USER_2|||1004|0|0|0 111603.789|event|TDX_CST|DE_TONEON|DISCONNECT_USER_2|||1004|0|0|0 111603.789|callstate|LINECALLSTATE_DISCONNECTED-DISCONNECT_USER_2|||||0|16384|64|0 111603.795|event|LINECALLSTATE_DISCONNECTED-DISCONNECT_USER_2|||||16384|0|64|0 111603.795|command|cmd_DropCall|||||0|0|0|0 111603.839|event|TDX_SETHOOK|DX_ONHOOK||||0|0|0|0 111603.840|callstate|TDX_SETHOOK_DX_ONHOOK|||||0|1|32|0 111603.844|event|TDX_SETHOOK_DX_ONHOOK|||||1|0|32|0 111603.844|callstate|GCEV_RELEASECALL|GCST_NULL||||2137|0|0|0 ", "length": "21.848" }}, The painted line is the VBScript it’s trying to run but it won’t continue to the next modules. Thanks. Share this post Link to post
SupportTeam Report post Posted 08/23/2021 11:21 PM Please post the "vgEngine" trace that captures the call. We can then see what happened on the call and advise. The vgEngine traces are created in VoiceGuide's \log\ subdirectory. Please .ZIP up the traces before posting. Share this post Link to post
Oliver Report post Posted 08/24/2021 08:02 AM Ok, I took a look into the trace file, I saw one error I already handled, which was it didn't find the file, the second error is indicating that I may try using WSH instead of ClearScript, I tried changing the engine as suggested in trace file but it still doesn't work. You can see both traces in ZIP file, my suggestion is to search for keyword "Yoman" to find the section with the script, hope it helps. Thank you for the support! vgEngine Traces.7z Share this post Link to post
SupportTeam Report post Posted 08/24/2021 08:48 AM The trace shows that the ClearScript interpreter that ran the [Check System Online] module reported: ERROR ErrorDetails: Input past end of file Probably next step would be to confirm if the system can read in the input data file. Recommend adding some Trace API calls to see how far the VBScript code progresses. see: https://www.voiceguide.com/vghelp/source/html/com_trace.htm As you are running an older version then you may need to use the older Admin_TraceLogAdd API call instead of the Trace API. https://www.voiceguide.com/vghelp/source/html/com_admin_tracelogadd.htm Share this post Link to post
Oliver Report post Posted 08/25/2021 04:06 PM Hi, thanks for the quick response, before I even tried adding the traceLog, I found out that the script needed a little "touch", since it was also alerting about a "End of File" error, I added an if statement to handle this error, but then I came to realize that I had an unneeded space in my If statement, and it kept alerting about an "Expected Then" error statement, once I fixed it the script ran smoothly but now I'm getting this error: 184330.231 24 3 2 not saving script (strIni_moduleRunScript_SaveToFile is False|0) 184330.231 24 3 2 runscr waiting. wait=1 184330.231 24 3 2 moh file not specified 184330.231 24 3 2 runscr call ClearScript Execute 184330.231 24 3 2 runscr new VBScriptEngine call 184330.232 24 3 2 runscr .Execute call 184330.233 25 rem remoting link constructor activated: vgServices_CommandLink 184330.234 25 rem Printed from trace: Starting vbscript 184330.236 25 rem Printed from trace: Created fileReadingObject 184330.242 25 rem Printed from trace: Opened text file with dates 184330.243 25 rem Printed from trace: Success 184330.243 25 rem Printed from trace: Starting to split lines 184330.244 25 rem Printed from trace: Starting to read each line 184330.259 25 3 2 rem Script_Goto 3, , Sorry, 184330.263 25 3 2 ERROR: COM interface not supported in this version. 184330.264 25 3 2 rem Script_Goto 3, , E_Sorry, 184330.264 25 3 2 ERROR: COM interface not supported in this version. 184330.265 24 3 2 engineVbs dispose call 184330.265 24 3 2 runscr .Execute returned. iRunWait=1 184330.265 24 3 2 runscr RunWait_1 script completed 184330.265 24 3 2 runscr sModuleClearScriptProcessWasCalledFrom is current module Check System Online, clearing setting 184330.265 24 3 2 runscr RunWait_1 taking fail path as script completed and no next module set 184330.265 24 3 2 FindNextVgmTitleInPathList: next module title is=[Get For English] Is there anything else I can do to make it work? Thanks Share this post Link to post
SupportTeam Report post Posted 08/25/2021 09:09 PM You need the "Enterprise" license to use Script_Goto and similar VoiceGuide API commands. Please see https://www.voiceguide.com/ivr-software/ivr-system-features.htm the "REST/COM/WCF/Remoting/etc. Interfaces" functionality requires Enterprise license. Please contact sales@voiceguide.com regarding upgrading your license from Professional to Enterprise. Share this post Link to post
Oliver Report post Posted 08/26/2021 08:04 AM I see, well thank you for the support and help! I'll be contacting you soon. Share this post Link to post
