Scriptgoto
Hello
I often use
vg.Script_Goto iLineId, sDestScript, sDestModule, sRvList
function to pass parameters from one module to another. Sometimes I do a return transfer (module 1 -> module 2 -> module 1).
Why i do use it: to retreive data from a database, than transform it and send to submodule. My menu is divided into module (separate files).
Are there any limitations of the method or a better way to accomplish my task?
Dominik
There are no limitations on using vg.Script_Goto
If you are using vg.Script_Gosub then there is a 'stack size' type limit - you can only drill down about 100 'subroutine' layers down... not a limit which would be in danger of being exceeded I think...
