Guest Guest_bobjdixon Report post Posted 03/17/2003 10:53 AM I'm using TTS with the VoiceGuide Enterprise Edition. When a call is answered I can hear the text prompt being spoken on my local machine but not over the telephone. If I use a preformed wav file with exactly the same script, the file plays on the phone OK. I've noticed that the tts0.wav produced in the system directory has a length of just 46 bytes (1K) Extract from the log is: 26907 0 Answer the call 26907 0 lineAnswer(66271) => 66254 26907 0 tapie callstate ACCEPTED 66271 0 0 27298 0 tapi Reply 66254 0 27308 0 tapie callstate CONNECTED 66271,0,0 27308 0 WorkingModeTAPI= 27308 0 WorkingModeScript= 27308 0 CID at StartLoadedVgs [] 27308 0 CID at RunModule% [] 27308 0 [Play 1] Playing 27318 0 tts generate start[Thank you for calling Durable Business Solutions. I'm sorry but we are not able to take your call at the moment. If you would like to leave a message, please press one.] 39075 0 tts generate end 39075 0 [Play 1] Playing (C:\Program Files\VoiceGuide\system\tts0.wav) 39075 0 PlaySoundStart ok [C:\Program Files\VoiceGuide\system\tts0.wav] 39075 0 RunModule PLAY end 83439 0 tapie callstate DISCONNECTED 66271,1,0 83439 0 LsPlayMsg EV_REMOTEPARTY_DISCONNECT 83439 0 PlaySoundStop ok Share this post Link to post
SupportTeam Report post Posted 03/17/2003 12:57 PM There should be no difference in output between pre-recorded WAV files and TTS generated files - TTS files get generated into a WAV file and then that WAV file is played the same way as a pre-recorded WAV file... As a test please try using two modules in the script - one which plays a pre-recorded WAV file, and the other which plays a TTS generated file. What happens then? Its strange that tts0.wav TTS is empty - is it being perhaps being overwritten later in the script from another module? Share this post Link to post
