Saving, Exporting, Or Printing Flow Diagram
From other postings, I see the print capabilities of VG will be enhanced in later releases. In the interim, I'm willing to do some extra "work" in order to produce a printable copy of using the current release. Is there any mechanism (or external utility) I can use to save or export a representation of the "virtual screen" that is used to present the flowchart? Cut & paste screen captures seems like the worst-case scenario. A utility that dumps the bitmap to a file would be the ticket, any suggestions?
/Rick
Right now there is no mechanism to export to graphical callflow...
Right now cutting and pasting screen captures would be the only possible approach.
Thanks. Is there any "screen scraping" type application that can capture the entire virtual screen? I've been experimenting with SnagIT (www.techsmith.com) but unable to capture anything beyond the visible screen.
/Rick
I'm not aware of any...
VG does use a 'virtual screen' type approach - so what is seen in the script designer window is just part of a bigger window with the entire script drawn on it - but I'm not aware of any capture packages which would be able to capture that as a bitmap...
