Dacian Florin Dedu Report post Posted 07/09/2022 04:53 PM Hello, How can i change the IVR scenario for Inbound calls ? It s playing one ivr script. Kind, Dacian Share this post Link to post
SupportTeam Report post Posted 07/10/2022 02:22 AM This is set in Config.xml file, which is in .VoiceGuide's \conf\ subdirectory. from https://www.voiceguide.com/vghelp/source/html/install_v7_dialogichmp.htm : Configuring VoiceGuide VoiceGuide configuration is set using the following files: VG.INI and Config.xml VG.INI file is located in VoiceGuide's main directory. Config.xml file is located in VoiceGuide's \conf\ subdirectory. Config.xml is used to set what lines/channels are opened by VoiceGuide and what script is to be used when answering incoming calls on each of those lines/channels. Sample Config files are provided showing how to set up the Config.xml file for larger systems. If not running as Administrator then some permission changes may need to be made to allow editing of Config.xml, VG.INI, etc. files. In Windows Explorer: Right click on the VoiceGuide directory Select Properties Go to the Security tab Make the necessary changes Alternatively, the text editor application used to edit the Config.xml, VG.INI, etc. files would need to be started using the 'Run as administrator' option. Then Windows will not block the saving of new versions of Config.xml, VG.INI, etc. files. Share this post Link to post
