Vb Script Questions
John wrote:
Another question about returning information from the called
Program or script back to VoiceGuide. The vbs is as following.
vg.Run_ResultReturn $RV_LINEID,  "[birth]{721111}"
br = $RV[birth]
msgbox br
set vg = Nothing
The message box popup but shows a previous value not "721111". Is
there anything wrong with my script?
The RV's in the VG Script are all replaced with the RV's current values before the script is ran...
So before running the script the "$RV[birth]" would be replaced with it's current value - and then the resulting .vgs file would be ran...
