Brandon Report post Posted 04/05/2004 03:44 AM Team, I am using the run module with the following line: command.com /c shntool.exe join -stdout name$RV[Get Digit ID].wav mortgage$RV[Get Digit ID].wav situation$RV[Get Digit ID].wav > fast$RV[Get Digit ID].wav By doing the above command it forces me to have all of the wav files in the c:\Program Files\VoiceGuide directory. How can I change this to another directory for example: c:\My Documents\Brandon\Recordings Next question: When doing command.com commands and working with directories do I need to stick to the DOS format or can use the windows format? Example: \My Documents\ being windows or \MyDocu~1\ being DOS Thanks, -Brandon Share this post Link to post
SupportTeam Report post Posted 04/05/2004 04:35 AM How can I change this to another directory Just specify the full directory path before the filename.. working with directories do I need to stick to the DOS format or can use the windows format I imagine both will work - just try it and see... Share this post Link to post
