Running Command /c From Different Directory
Team,
I am using the run module with the following line:
command.com /c shntool.exe join -stdout name$RV[Get Digit ID].wav mortgage$RV[Get Digit ID].wav situation$RV[Get Digit ID].wav > fast$RV[Get Digit ID].wav
By doing the above command it forces me to have all of the wav files in the c:\Program Files\VoiceGuide directory. How can I change this to another directory for example:
c:\My Documents\Brandon\Recordings
Next question: When doing command.com commands and working with directories do I need to stick to the DOS format or can use the windows format?
Example:
\My Documents\ being windows
or \MyDocu~1\ being DOS
Thanks,
-Brandon
Just specify the full directory path before the filename..
I imagine both will work - just try it and see...
