Guest Guest_Mehdi Report post Posted 04/06/2004 04:10 PM Hi there, I would like to know if I can use more than one PCI Boards using VGdialer. Does VG Dialer take all lines from alla board installed .. Thanks for your help .. Share this post Link to post
SupportTeam Report post Posted 04/06/2004 09:55 PM You can use multiple boards. You can select which channels VoiceGuide will use on a per-channel basis. In most cases you would just select to use all channels on all boards in system. Share this post Link to post
