Brett Report post Posted 04/07/2004 10:08 PM my new problem: why does the last line (from the below log file) error mean? transfer was working but now not. only change I can see is pbx techs put in new cable but they believe they havent changed anything, so i need to know what that last line means? TIA 080212.28 7 [Play Please Hold] Playing 080212.28 7 [Play Please Hold] Playing (WAVS\transfer.wav) 080212.30 7 PlaySoundStart ok [C:\Program Files\VoiceGuide\Scripts\tender\WAVS\transfer.wav] 080212.30 7 TimeoutClear 080212.30 7 RunModule PLAY end 080212.30 7 wa(3490,92696800) 080212.30 7 callinfo MONITORMODES 080215.84 7 wb(92696800) 080215.89 7 Play End line[7] (id=926968) 080215.91 7 ScriptEventCode 8001 iLineState=1100 080215.91 7 LsPlayMsg EV_PLAY_FINISHED 080215.91 7 TimeoutSet 10 EV_TIMEOUT_HANGUP 080215.91 7 TimeoutSet 0 EV_TIMEOUT_GOTOMODULE 080215.91 7 ScriptEventCode 9002 iLineState=1101 080215.91 7 LsPlayMsgFinished EV_TIMEOUT_GOTOMODULE 080215.91 7 TimeoutClear 080215.91 7 TimeoutSet 0.4 EV_TIMEOUT_READYTOBEGINTRANSFER 080216.25 7 Timer fired EV_TIMEOUT_READYTOBEGINTRANSFER 080216.25 7 ScriptEventCode 9012 iLineState=1900 080216.25 7 LsXferStart EV_TIMEOUT_READYTOBEGINTRANSFER 080216.25 7 TimeoutSet 60 EV_TIMEOUT_ANNOUNCED_TRANSFER_ATTEMPT_TOOK_TOO_LONG 080216.25 7 [Transfer Call GE] Blind Transfer to 103 (TAPI) 080216.25 7 lineBlindTransfer(65810,103,0) in LsXferStart => 65622 080216.27 7 tapi Reply (LineEvReply) err 65622 LINEERR_OPERATIONUNAVAIL [80000049] Share this post Link to post
Brett Report post Posted 04/07/2004 10:19 PM sorry that should read what does not why does!!!! too early! Share this post Link to post
SupportTeam Report post Posted 04/07/2004 10:31 PM Are you using a Dialogic card, a modem or some other device? Is this an incoming call or outgoing call? In VG.INI please try changinh TransferControl_Modem and TransferControl_TelBoards to: TransferControl_Modem=Generate TransferControl_TelBoards=Generate Share this post Link to post
Brett Report post Posted 04/07/2004 10:47 PM Dialogic D/4PCI incoming call being transferred to handset Share this post Link to post
Brett Report post Posted 04/07/2004 10:50 PM the INI changes u suggested have solved the problem. Thank you. Share this post Link to post
