Go To Multipul Modules On Success
Can I set voiceguide go to multipul modules on success? For example, Press 1 go to database query module and go to play sound module also.
No, you can only go to one module at a time. Usually database queries take a fraction of a second so there is no need to play any music while doing a database query.
If you have a situation where the database transaction will take a longer time and you would like to play some message to caller in meantime then you could use a VB Script module to perform the database query. VB Script module can play a message while running the VB Script is running.
