Openrecordset: 3146:odbc--call Failed.
Newbie considering purchase of enterprise system...
I am trying to open an ODBC Datasource but I keep getting the following error...
OpenRecordset: 3146:ODBC--call failed.
Here is a larger part of the log....
005736.71 6 [Load_Sys_Param] DB Query
005736.74 6 db ODBC mode used
005743.67 6 db About to execute a Retrieve type operation [sELECT Sys_Status, P_ANI, P_Acnt_No, PBX_Acnt_Code, PBX_Xfer_Code FROM Sys_Param WHERE Sys_Status = 'ON';]
005746.15 6 OpenRecordset: 3146:ODBC--call failed.
005746.45 6 TimeoutClear
005746.47 6 [Cannot_Cmplt_Call] Playing
How does this relate to Microsoft's Knowledge Base Article - 126940 located at http://support.microsoft.com/default.aspx?...en-us%3BQ126940
Which database are you trying to connect to?
I am trying to connect to an Access Database. The Database is name paremeters.mdb with the only table named Sys_param.
What are you using for datasource name and connect string?
Datasource Name: "Parameters"
Connect String: ODBC;DRIVER={Microsoft Access Driver (Parameters.mdb)}
Have you defined the ODBC datasource as per http://www.voiceguide.com/vghelp/html/conf...cDataSource.htm ?
Yes... I',m familiar with setting up an ODBC datasource (See next answer)
Can you try running a simpler query and see if maybe some queries work for you and some do not?
Yes... It works for another call later in the script using a different ODB Source.
Your ODBC Connect String in this module seems to be wrong. Please see the VG help file for a specific example on using MS Access via ODBC and the connect string used in this case. It should be:
ODBC;DRIVER={Microsoft Access Driver (*.mdb)}
If you are connecting to the local Access Database then you can also just specify the database filename (& full path to it) in the "Database" field - then you do not need to specify any ODBC Connect String at all - again there are more examples on this in VG Help file's section on DB Query module.
It works for another call later in the script using a different ODBC Source.
... so maybe you should look at what settings are used in that other module and use them in this module as well...
Check your table permissions. I ran into the same issue connecting to a Sybase database through Sybase OCOS and I needed to grant update access to one of the tables.
